3D problems on PC. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By w1070hfr
post #1 of 11 Old 07-31-2014, 06:58 PM - Thread Starter
Vivek Sood's Avatar
Question 3D problems on PC.
Hi,
I am not able to play 3D content on my PC. My config is in my siggy.
Uing PowerDVD to play. Whenever I install PowerDVD for the first time after a fresh install of Windows 8.1 Pro it plays for some time then It never plays! Virtualclone drive is unable to mount 3D and if it does PowerDVD is unable to play it anyway.
Any idea what could be the issue?
ATI Drivers?
i5 4440 - H97M-DS3P - Vengeance 8GB - 850 Pro 128 GB SSD - R7 240 - L42ET60/S2240L - Swans M50w - Xonar DX - ATH-M50 - E10 - 5 TB - VS350 - Carbide 400R - Hauppage MCE Remote Control - Windows 10 Pro x64.
Vivek Sood is offline
post #2 of 11 Old 08-02-2014, 08:00 PM
w1070hfr's Avatar
Quoted: 18 Post(s)
I've had issues of my own when I first tried to play 3D from my computer. The problem was that my computer was set to 60hz. Setting it to 24Hz worked out. Now depending on the type of file (HSBS, TopBottom or Frame Packing) the result can vary. You can output a 3D signal to your TV or you can also try to output side by side for instance and then have the TV process it in 3D. One can work better than the other depending on the situation.
Vivek Sood likes this.
w1070hfr is offline
post #3 of 11 Old 08-02-2014, 09:23 PM - Thread Starter
Vivek Sood's Avatar
Thanks. When I installed PowerDVD and tried playing 3D ISOs it played and changed from 60hz to 24 automatically. After a reboot (next day) that stopped happening. (The auto change from 60 to 24 and back once 3d was stopped) Looks like I will have to change refresh rate manually every time I play 3D!
post #4 of 11 Old 08-02-2014, 10:09 PM - Thread Starter
Vivek Sood's Avatar
I changed ATI Catalyst I changed it from 60 to 24hz and confirmed changes on the TV too. I get a green dotted lines on my screen when I try to play 3D now.
post #5 of 11 Old 08-03-2014, 12:26 AM - Thread Starter
Vivek Sood's Avatar
Installed TMT. On starting 3D ISO playback TMT changes TV to 25p instead of 24 so I have to manually change it from ATI Catalyst center to 24p and it is working as of now.
post #6 of 11 Old 08-10-2014, 08:33 PM - Thread Starter
Vivek Sood's Avatar
Update: 3D working fine for more than a week now lol. Thanks. You did point me to the right direction. I had a feeling it had something to do with refresh rate.
post #7 of 11 Old 08-16-2014, 06:19 PM
w1070hfr's Avatar
Quoted: 18 Post(s)
Glad it helped. Sorry I did not follow through but with holydays and all...
3D on PCs is a bit of an unchartered territory at this point. You have to find ways to make your setup work. For instance, I still cannot play proper subtitles from my PC.
After a little more than a year with a 3D projector, a PS3 and a PC, I have to say that nothing beats the 3D bluray in my view although quality among them can vary. Also I think Avatar is still the best movie on 3D yet. James cameron is the only one who really thought 3D could enhance his movies and not just be a marketing gitzmo. Not to say that no other movies are spectacular in 3D but few are thought to be first and foremost 3D movies. Also if you like 3D, I think a projector is truly a must. :-)
w1070hfr is offline
post #8 of 11 Old 08-17-2014, 07:09 AM - Thread Starter
Vivek Sood's Avatar
There are hardly any titles in 3D.
This docu has very good 3D effects:
http://www.imdb.com/title/tt0240143/
Though a very simple short movie. Love it for the 3D effects. Much more pronounced than Avatar.
post #9 of 11 Old 09-05-2014, 10:43 AM
Liked: 0
hello.
I have three Panasonic PT-CW331 projector. The manual says it is capable to 120Hz at 1280x800 resulotion. But after a short use I realized it changed res. to 1024x768. The idea is a three sceen system with one output source (3 vga card PC) and extended view desktop/applicaton. I turned off the projectors 3D option, and used Nvidia 3D vision. Did this because the projectors own glasses can not sync the three projector sceens for one glasses,(one glasses for each projectors is not good for me but with nvidia the hw does the sceen sync and only one glasses is requied. But after I turned on the nvidia stereo the screen res changed to 1024x768. This is not good for me because I have a 16:10 wide screen. Any idea????
Is there any device for the projector glasses that capable to sync the three sceens for one glasses like nvidia 3D vision? Thanx.
gyuri86 is offline
post #10 of 11 Old 09-05-2014, 11:20 AM
Quoted: 49 Post(s)
Liked: 37
This looks like a graphics card limitation; why not get a modern card with 3 HDMI/DVI outputs? (not sure if there is an NVidia one, but I thought three digital dipslays had not been a problem for a while now).
Roussi is offline
post #11 of 11 Old 09-05-2014, 01:40 PM
Liked: 0
there is three GTX 780ti. that should be enough. the cw331 projector officially not support the nvidia 3d vision. I guess it maybe a problem too.
gyuri86 is offline
Reply 3D Tech Talk
