Can you compress 3d video ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-12-2014, 10:04 AM - Thread Starter
vistadelloco's Avatar
So I finally decided I want to add my 3d movies to my HTPC.
I normally use Makemkv to rip and Handbrake to compress my movies, so I thought id give it a try on 3d.
I ripped the 3d movie (mvc file I believe) using makemkv , Works great pc/tv auto switches to 3d everything ok
Then I compress using handbrake and now seems to have lost 3d component. Does Not auto detect 3d and if I switch manually it seems to be giving 2d - 3d conversion
?'s
any thing I need to change in handbrake settings or
can you compress 3d movies to smaller size at all
if so how
what program
thanks for help (Harold&Kumar:Christmas3d ripped was 26GB after Handbrake 2.49GB)
vistadelloco is offline
post #2 of 4 Old 08-12-2014, 02:05 PM
Quoted: 47 Post(s)
Liked: 37
I am quite sure Handbrake cannot recompress MVC to MVC. It's the first time I see someone attempting this. Your only option is probably ripping to side-by-side (full or half) AVC; Handbrake shouldn't have a problem recompressing that. You will have very limited options with playing the full SbS, AFAIK.
Roussi is offline
post #3 of 4 Old 08-14-2014, 09:42 AM - Thread Starter
Well instead of adding movies. I guess ill just add 3d clips
post #4 of 4 Old 08-19-2014, 01:14 PM
fmedrano1977's Avatar
Quoted: 348 Post(s)
Liked: 104
BD25 ISOs of 3D movies are exactly this and range around 18-22 GB in size.
fmedrano1977 is offline
Reply 3D Tech Talk
