LG CF3D - a decent projector in 2014? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-13-2014, 04:15 PM - Thread Starter
Liked: 3
I checked the thread on this PJ here on AVS but it's from 2011. Is this PJ ancient history spec wise? Any experiences and/or comparisons more recently?
Gadgety1 is offline
post #2 of 7 Old 08-14-2014, 11:34 AM
BlackShark's Avatar
Quoted: 43 Post(s)
Liked: 25
I haven't heard from this projector since it's introduction.
I think the main problem with this projector was it's price, it's much cheaper to build your own dual projector system than buying LG's all in one unit.
I don't know anyone who owns one.
Passive 3D, forever !
My Full-HD dual-projector passive polarised 3D setup. (really out of date ! I need to update it some day...)
BlackShark is offline
post #3 of 7 Old 08-15-2014, 09:51 AM - Thread Starter
Liked: 3
Thanks. I saw it for $3200 recently.
Gadgety1 is offline
post #4 of 7 Old 09-10-2014, 08:45 AM
harkerad's Avatar
I grab that $3200 unit
Gadgety1
I grab that unit at $3200, and am hoping it all works out to take my theater from standard 720P projector to 1080P and passive 3d. I've been collecting glasses at the movies and have a 47" Vizio for my Kid that we watch now and then for a 3d movie. I just need to work out the screen at this point.
I'll post on my impressions but I can't see it being much different than other 1080P projectors except in contrast. Brightness it might exceed many of the projectors that are not the latest and greatest. We'll see very soon when my shipment comes in.
Wish me well with this.
Update; Well so far I'm having issues with my screen. I bought the Elite CineGrey 5D. It isn't working out well. I contacted Elite and they are not helping much, they basically said to return the screen without attempting to help. Well they did suggest flipping it upside down. Now, I knew this wouldn't help, but obliged them with this request. After the struggle of inverting a 150" screen, there was no change in the image. The ghosting is terrible. This screen is advertised to keep Polarization but doesn't. I'm getting a Harkness ordered soon which is in many of the local theatres with 3D.
I do on some clips see spectacular 3d on this large screen with this projector. The ghosting is still there but not as noticeable because of color and detail of the images.
Anyone have recommendation for Screen?
harkerad is offline
post #5 of 7 Old 01-02-2015, 08:16 AM
harkerad's Avatar
Well, here is the update of my setup. Bought a proper mount for the heavy LG CF3D. Bought an 150" Elite screen that was suppose to be good for passive 3D, but wasn't. Did more research and read some good info here on AVS that lead me to purchase a Harkness custom sized screen 145". Mounted the projector and screen, hooked up my 3D blueray and started Avatar. Amazing!!!
I'm getting the service remote to tweak the image alignment because 3D looks great but 2D is well not good. Reading here on AVS, I found a thread that addressed this and it is simply a fine tuning adjustment that a factory rep would normally do. Well for $40 buck and online instructions, I can do it myself.
I expect that after that I'll have no complaints at all and the 3d will look even better/sharper/cleaner.
For the price I paid, It was definitely well worth it compared to the two projector setup. It's quieter than 2 projectors and easier to adjust. The only down side I can see is that I can't go 4K by simply swapping projectors down the road. I'm hoping that by then one company goes back to this idea of one unit doing it all.
harkerad is offline
post #6 of 7 Old 11-07-2015, 08:47 PM
Liked: 0
hi hARKERAD
How did you go calibrating the CF3d? did you get the remote and did it work?
Cheers
Ashley Carey is offline
post #7 of 7 Old 11-07-2015, 09:50 PM
harkerad's Avatar
I did the recalibration suggested in an AVS post about the CF3D titled " is my projector broken or does it need adjustment". In there it states the remote model and instruction to get into the device menu.
It was pretty easy and it turned out great. I haven't touched the projector since and it's still looking wonderful. 3D looks as good as my local theatre. Guardians of the galaxy is my fav so far along with Avatar!
The major thing is this fixed 2d. I can use it for standard computer work and it doesn't look blurry anymore. Saw a lot of ghosting in 2d before calibration. Now it's good.
If you need more help post here again and I'll try to assist.
harkerad is offline
Reply 3D Tech Talk
