What is Optoma doing on 3D glass/emitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-15-2014, 05:36 PM - Thread Starter
Liked: 0
Unhappy What is Optoma doing on 3D glass/emitter?
I have got a HD25E package recently with BC300 emitter and two pair of ZF2300 glasses. Yesterday, I have also got two pair of ZF2100 glasses. But then, I found ZF2100 is not going to work with BC300 emitter, and I have to use BC100 emitter to get Zf2100 work. okay, now I am stuck, I can never watch a movie to mix ZF2100 and ZF2300 glasses.
I have seen there are some discussion in this forum about Optoma 3D glasses. Anyone has a clue, what happened? I just like to understand..
seanxushen is offline
post #2 of 9 Old 08-17-2014, 09:03 AM
Rolls-Royce's Avatar
Quoted: 398 Post(s)
Liked: 564
I don't think anyone really knows at this point. Optoma's website says the ZF2300 glasses must be used with the BC300 emitter and are not backwards-compatible. That's all.
You may want to consider contacting Optoma or Bit Cauldron (the actual manufacturer) with your question. Bit Cauldron has helped me in the past, so they may be a good source if Optoma doesn't respond.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 9 Old 08-20-2014, 02:25 PM - Thread Starter
Liked: 0
I called Optoma, the only answer they gave to me is that ZF2100/BC100 and ZF2300/BC300 are not interchangable.
post #4 of 9 Old 12-25-2014, 04:14 PM
Greg_R_STL's Avatar
Quoted: 16 Post(s)
Liked: 25
If anyone has a clear answer on this, let me know.
Greg_R_STL is offline
post #5 of 9 Old 05-04-2015, 02:12 AM
Frank714's Avatar
Quoted: 695 Post(s)
Liked: 281
My friend has the ZF2100 and wonders if the ZF2300 does constitute an improvement?
I still have the old "Ray-Ban" Optoma / Bit Cauldron glasses from 2011 (and managed to increase brightness by finally re-installing one of my old glass beaded screens).
But soon I will need RF 3D glasses for my youngest son. Does anybody have an idea where to get children-suitable 3D glasses?
P.S. Never mind, looks like the RF 3D glasses for kids by 3DTV Corp. are the most promising ones and just came out last December (no customer reviews, yet).
But there is some interesting information: "(Neither these nor any others are compatible with Optoma BC300 RF Emitter and ZF2300 glasses)"
Thus, if you have smaller children, you should not go for the BC300 RF emitter and the ZF2300 glasses, as you apparently won't be able to later purchase 3D glasses to fit your youngest.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #6 of 9 Old 12-04-2015, 01:27 AM
SuperDre's Avatar
sigh.. typed a large message but the board just ditched it, so a small version (and now in Chrome as it seems it has a problem in IE11)..
You can use a 3D vesa splitter for using multiple emitters (so you can use the BC100 and BC300 at the same time), I know hishock is selling one: https://www.hi-shock.de/detail/index...45/sCategory/8
I have a Optoma HD131 and have the original ZF2100, but I hardly use them now after I bought a hishock 3D RF Pro vesa kit (https://www.hi-shock.de/3d-systeme/s...er-optoma?c=29). It has a bluetooth transmitter and the glasses themselves are IMHO much better than the ZF2100, they are lighter (weight) and seem to be a bit more transparent, but the glass itself is certainly a bit larger than the glass of the ZF2100.. The advantage of the bluetooth transmitter is that you can buy just any bluetooth 3d glasses (and they are pretty cheap if you look on Aliexpress or other sites)..
I too wonder if the ZF2300 are much better than the ZF2100, if so I might just pickup a pair.. Also I wonder if the BC300 transmitter is a bluetooth transmitter, but I doubt it is..
SuperDre is offline
post #7 of 9 Old 06-20-2017, 11:31 AM
Liked: 0
im on the hi shock site but cant find the optoma compatible bluetooth set only an rf set on the hishock site. can i still buy cheap glasses. found the splitter for my zf 2100
Andrew Knox is offline
post #8 of 9 Old 06-20-2017, 11:32 AM
Liked: 0
Hi-shock® advance kit rf for optoma [power light]
post #9 of 9 Old 06-20-2017, 01:00 PM
SuperDre's Avatar
This is the original one I bought back then: https://www.amazon.de/HiShock-Full-P...hishock+optoma
And it didn't say anything about Bluetooth, but it is a Bluetooth transmitter.
This is the current version: https://www.hi-shock.de/hi-shock-adv...2.4g-rf-144-hz
But you can always ask them if it's actually a Bluetooth transmitter like the version from amazon.
SuperDre is offline
Reply 3D Tech Talk
3d glasses , Optoma
