Making your 3-D glasses more comfortable. - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By Nigel79
  • 1 Post By deano86
post #1 of 5 Old 02-16-2017, 07:02 PM - Thread Starter
Nigel79's Avatar
Liked: 3
My glasses were pretty uncomfortable because I have a big head and the inside of the stems are notched out and not flat. If you have the same problem or you think this would make yours more comfortable try it out. I took shrink tubing and shrunk two pieces over the stems and it made them much more comfortable.
SRTpusher and 3DBob like this.
Nigel79 is offline
post #2 of 5 Old 02-19-2017, 04:45 PM
Liked: 0
Pretty easy tip. I'll have to try it out.
tdsounds is offline
post #3 of 5 Old 07-27-2017, 12:44 PM
Liked: 0
My young niece has a small nose and wearing her glasses under the 3d glasses meant they kept falling down. I removed the stems and ziptied the glasses together for a comfy fit.
So there's another option, zip tie one pair of glasses to another
bitJericho is offline
post #4 of 5 Old 07-28-2017, 11:03 AM
deano86's Avatar
Quoted: 305 Post(s)
Liked: 154
I remember the original Sony Playstation active 3d glasses had a very aggressive bend to their temples..... literally squeezing on the sides of your head above your ears... which literally would start to give me a headache before the end of a movie. I found an effective fix to be the hot water/cold water trick. Get a pot of water on the stove and get it very hot ... probably doesn't have to be boiling.. . I would dip one temple in the hot water for a minute or so. This makes the plastic very maliable and I would bend it out a bit and hold it in place, then quickly take it to the sink and run it under cold water to "set" it in its new position.... Then just repeat for the other temple. This was quite effective in taking the excessive "squeeze" out of the glasses... making them much more comfortable for those with a larger head!
Maintower likes this.
deano86 is offline
post #5 of 5 Old 09-15-2017, 12:25 PM
SRTpusher's Avatar
Originally Posted by Nigel79 View Post
Attachment 1974353
like the Oakley earsocks...
Home Theater / Game Room
110" Elite Screens Spectrum motorized screen - Epson 2030
Atmos 7.2.4 - Onkyo TX-NR1030 - Onkyo M-5010 2ch amp - Fluance XL Fronts, Center and Surrounds, Rear Monoprice 4101 8" kevlar in-wall, Ceiling Yamaha NS-IW280CWH - Subs 2x NXG Technology NX-BAS-500
SRTpusher is offline
Reply 3D Tech Talk
