3D Ghosting with the LG OLED65E6P - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-21-2017, 04:53 PM - Thread Starter
Dreambo's Avatar
Quoted: 55 Post(s)
Liked: 3
Especially with the 3D version of "Dr. Strange" I am seeing ghosting on the bottom left hand corner of my LG65E6P and with Subtitles on the extend to the left hand side of the screen are ghosting like crazy and I do not know what to do.
Changed to Manual and Auto...nothing.
Have any of you experienced this? I am also using my new Oppo 203 as the 3D player...
Dreambo is offline
post #2 of 2 Old 05-12-2017, 12:23 PM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
The ghosting can be eliminated by either or a combination of adjusting the screen or sitting height and seating distance from the screen in most cases. For me, if I stand up, I see it but if I'm sitting down it's gone. Try adjusting a few things to see what happens. Again, in most cases you can get rid of it. LG will tell you that the ghosting is normal. If your set is within your return window (at the place of purchase) and want to try another set it's up to you. You never know what the next set may be like it could be perfect, better or worse.
jbug is offline
Reply 3D Tech Talk
