AutoCad 2007, 2011 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-26-2017, 08:37 AM - Thread Starter
Liked: 0
AutoCad 2007, 2011
Hello!
I have a question. Knows anyone how to recover .dwg file? I have a file which won't open in AutoCad 2011 and says "drawing file is corrupted"! Is it possible to do recovery if file .bak file is not there? Only .dwg!
Through the recovery Manager do not work. The file was created in AutoCad 2007.
StefanEinarsson1 is offline
post #2 of 5 Old 06-26-2017, 08:39 AM
Quoted: 331 Post(s)
Liked: 155
Originally Posted by StefanEinarsson1 View Post
Hello!
I would recommend the AutoCAD forums on their site for this. There are I am AutoCAD users on this site but this is place is geared towards audio and video.
liffie420 is offline
post #3 of 5 Old 06-27-2017, 03:55 AM - Thread Starter
Liked: 0
Clear. Thank you for the advice. I'll try to do as you said.
post #4 of 5 Old 06-27-2017, 07:41 AM
thomas.mckenna's Avatar
Liked: 0
To insert the file as the link or the block.
It is possible to try into the new file insert "damaged" file as the external link or the block.
To insert a file as an external reference:
• on the menu bar, go to Insert - the Link to DWG and to choose the necessary file;
• enter the command _.xref and select the desired file.
To insert a file as a block:
• on the menu bar, go to Insert - Block and choose the file;
• enter the command _.insert and select the desired file.
If this does not help, then use dwg recovery software DWG Recovery Toolbox for this purpose.
https://www.oemailrecovery.com/dwg_recovery.html
thomas.mckenna is offline
post #5 of 5 Old 06-27-2017, 09:59 AM - Thread Starter
Liked: 0
Thank you guys for your feedback and help. Thank you!
Reply 3D Tech Talk
