What do I need to do in order to watch movies on my 3D ready DLP projector - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rekbones
post #1 of 3 Old 09-12-2017, 03:27 PM - Thread Starter
Liked: 0
I have been looking around on the internet and have found a range of conflicting information.
Currently I have an Acer x110 DLP 3D ready projector and DLP active 3D glasses and wish to watch 3D films from my laptop.
My Acer Aspire has an Intel i5-2450m (2.50GHz) 8GB RAM
Intel HD Graphics and Nvidia GeForce GT 520m.
What programs/further information do i need to enable to to watch 3d films with dlp link glasses (i read somewhere 3d vision and Stereoscopic player doesnt work with dlp glasses) can anyone help me?
I not very well versed with 3D so if any further information is needed please ask away.
Dry1471 is offline
post #2 of 3 Old 09-12-2017, 08:46 PM
rekbones's Avatar
Quoted: 505 Post(s)
Liked: 257
If your projector is capable of playing SBS (side by side) or OU (over under) then virtually any video player can play those files. Search in Youtube for 3D, play the video in full screen you should see two images side by side (or OU), in projector menu enable 3D SBS (OU), turn on your glasses. To play full screen frame packed is much more difficult as your HDMI must be 1.4 and only ISO files played with PowerDVD work, their are other options I won't go into here.
EDIT: the easiest and cheapest is to buy a 3D capable BR player with 3D BR disc.
mauldo67 likes this.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 3 Old 09-13-2017, 12:41 PM
Quoted: 49 Post(s)
Liked: 37
This appears to be an analog 120Hz frame-sequential 3D capable projector. Your only option is the PowerDVD software player with that (or similar worded) output setting; or Stereoscopic Player (3dtv.at; I am not familiar with it) for non-protected video.
Edit: assuming that the laptop has VGA out.
A dedicated player or a converter box are not feasible, as the video input appears to be only VGA.
(I was not able to make PDVD 16 run 3D frame-sequential through HDMI, although the setting was available.)
Roussi is offline
Reply 3D Tech Talk
