sub for soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-02-2008, 03:50 PM - Thread Starter
ramsay22's Avatar
In am looking to buy a soundbar and would like to use a subwoofer I already have for a home theater system. How do you determine compatibility of a sub with a new soundbar??
ramsay22 is offline
post #2 of 3 Old 05-02-2008, 06:20 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Many of us are probably unfamiliar with how sound bars connect to receivers. But, assuming that the sound bar simply connects to some or all of the receiver's speaker outputs, then the sub would be connected conventionally to the receiver's subwoofer output with the receiver's settings set appropriately.
What sound bar(s) are you considering?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 3 Old 05-02-2008, 06:33 PM
Paul Scarpelli's Avatar
Liked: 54
The bass response of most "sounbars" is fairly anemic, and usually starts to roll off at 120 Hz-150 Hz, regardless of their published spec. Whatever sub you decide upon will need to be placed close to the soundbar so it isn't easily localized. Then, I would expect the result to be quite good.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
Reply Soundbars
