2.1 vs 3.1 etc...Need some clarification here on soundbars - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-17-2008, 08:11 PM - Thread Starter
beachfront71's Avatar
Hi and thanks.
So I have the Sony CT100 and the Phillips 8100, I am picking up the Samsung x810 tomorrow.
My confusion is as follows:
Knowing all 3 of these systems have subwoofers....the sony has a 3 speaker soundbar, the phillips has a 6 speaker soundbar (3 tweets/3 mids) and the samsung has a 2 speaker sound bar.
I am hoping the samsung blows me away but ....
how can I expect a 2 speaker soundbar to provide a better virtual surround experience than a soundbar that has 6 (phillips) or even 3 (sony) speakers to take advantage of?
Is there something I am missing here? More speakers seem like they should be able to direct different sounds better than 2 but Samsung has clearly marketed this system as a 2.1 virtual replacement.
If someone can shed some light here it would be appreciated as I am probably not the only one wondering about this.
Thanks and appreciate the time.
beachfront71 is offline
post #2 of 5 Old 06-18-2008, 02:11 AM
HD_Lantern's Avatar
Probably impossible to say without demo'ing each of those soundbars you listed. You might want to check out a recent soundbar article from Home Theatre Magainze, which compares multiple models (not sure off-hand if they covered your specific models, but it gives a good overview of the current state of soundbars).
http://www.hometheatermag.com/compac...und/index.html
HD_Lantern is offline
post #3 of 5 Old 06-18-2008, 05:46 AM
lawyerwatanabe's Avatar
Quoted: 32 Post(s)
Here is another link. How Virtual Surround Sound Works.
http://electronics.howstuffworks.com...ound-sound.htm
lawyerwatanabe is offline
post #4 of 5 Old 06-18-2008, 08:41 AM - Thread Starter
I appreciate this info but let me try and be a little more specific..
How can a soundbar with 2 speakers in it create a better virtual sound environment than a sounbar with 6 or even 3 speakers?
post #5 of 5 Old 06-18-2008, 10:01 AM
Quoted: 32 Post(s)
In terms of the sound environment that they're able to produce, it doesn't have much to do with the number of speakers but rather the sound processing algorithm being used.
Having 3 speakers, it would eliminate having to simulate the center channel, but I doubt simulating the center channel is that hard to do (just play through both speakers at the same volume). I'm not sure how the Yamaha soundbars work, which I hear has 40-50+ speakers in them.
Please refer to the link for more detailed information. It does a much better job at explaining how virtual surround sound works. It'll answer your 2 vs 3 speaker question once you understand how simulated surround works.
Reply Soundbars
