Soundbar vs. AVR w/2 speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-11-2008, 09:39 AM - Thread Starter
dmaxdmax's Avatar
Quoted: 22 Post(s)
I know there are plenty of discussions comparing soundbars to 5.1 or 7.1 but what about plain ol' 2.1?
I have a small room where at least 1 seat and probably 2 will be right next to a rear satellite which can't be good for surround. I was ready to get a soundbar (probably the Sony 100) but it occurred to me that a receiver plus 2 speakers (plus sub) might give me better results. 70% of the time will be spent watching cable or BR disks, 10% Wii and 20% music.
I love the Sony price, ease of setup plus there's no need to buy an AVR.
Any thoughts?
dmaxdmax is offline
post #2 of 4 Old 09-11-2008, 09:43 AM
fireman325's Avatar
Quoted: 14 Post(s)
What kind of blu-ray player are you using? If it's a PS3 or some other player that decodes Dolby True HD and DTS HD MA to multichannel LPCM, then the soundbar is all you need. If you're using a player that has to send the lossless audio to a receiver to be decoded then you will need a receiver capable of doing so.
And just fyi, the Sony HT-CT100 soundbar is 3.1, not 2.1. It has a left, right and center, as opposed to just left/right.
Steve
fireman325 is offline
post #3 of 4 Old 09-11-2008, 10:43 AM - Thread Starter
dmaxdmax's Avatar
Quoted: 22 Post(s)
Thanks. A PS3 is on order but does all that format stuff actually matter if I'm only using a soundbar or 2.1/3.1 speakers?
dmaxdmax is offline
post #4 of 4 Old 09-11-2008, 10:51 AM
fireman325's Avatar
Quoted: 14 Post(s)
Difficult to say for sure. I like the Sony soundbar for simplicity. One cable between the PS3 and soundbar and another from the soundbar to the TV and you're done. If you with a separate receiver, then I would definitely get one capable of all the latest audio, just in case I ever decided to expand the system to 5.1 or 7.1.
Steve
Reply Soundbars
