Soundbar with L/R/C in it. CinemaStick or P400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-28-2008, 02:28 PM - Thread Starter
hevnbnd's Avatar
Hello, I am looking for some sort of speaker solution that has my front Right, Left, & Center channel speakers in it. I know there are lots of companies with 5 channel, but I just want three channels and I will run separate rears. Has anyone used or have any experience with the Boston Acoustics P400 or the SpeakerCraft Tantra CinemaStick
I am by no means stuck on these two brands, but I think a bar will produce the cleanest sound. Anyone? Thanks
hevnbnd is offline
post #2 of 3 Old 10-28-2008, 05:08 PM
weaselorlando's Avatar
I used these
http://www.atlantictechnology.com/de...asp?NodeId=116
with a customer. They sounded good. I have not finished tweaking the system because they had not installed carpet or furniture in the room. I purchased them from Matt here at AVS.
Rich
weaselorlando is offline
post #3 of 3 Old 10-28-2008, 08:53 PM - Thread Starter
hevnbnd's Avatar
Very nice... Might be a little out of my budget, but we will see. Anyone else have any input?
hevnbnd is offline
Reply Soundbars
