receiver for polk soundbar and sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-06-2009, 05:07 PM - Thread Starter
hops33n's Avatar
Could anyone advise at to what receiver I should get for these two items: surroundbar 50 and dsw pro 600? I will also be hooking up a direct tv hd dvr and xbox 360 via hdmi to the receiver and hdmi to samsung tv. Thanks in advance
hops33n is offline
post #2 of 7 Old 01-27-2010, 10:12 AM
ssmike's Avatar
I'm bumping an old thread to see if anyone has insight on this issue.
I'm assisting a friend, and he is going to run this same SurroundBar 50 and sub.
The Polk soundbar is 5 channel.
ssmike is offline
post #3 of 7 Old 01-27-2010, 10:41 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Doesn't the soundbar do everything a receiver would? Many soundbars do. It would help if you listed more details on the soundbar. I should not have to go look it up to answer your question
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 7 Old 01-27-2010, 10:56 AM
ssmike's Avatar
http://reviews.cnet.com/speakers-spe...-32780776.html
Here's the CNET skinny. I had never even heard of this deal before yesterday.....
Product summary
The good: Virtual surround speaker housed in 51-inch-wide extruded aluminum cabinet; proprietary SDA technology produces room-filling spacious sound from the single-speaker design; nine 3.5-inch midrange drivers, three 0.75-inch silk dome tweeters; shelf stand, wall mount bracket, and color-coded 15-foot speaker wire is also included.
The bad: Somewhat expensive; you'll also need an AV receiver and a subwoofer.
The bottom line: The Polk SurroundBar 50 sounds great with music and movies, making it a worthwhile improvement over the company's earlier single-speaker surround offering.
"The SurroundBar 50 is a five-channel speaker, but uses nine 3.5-inch midrange drivers and three 0.75-inch tweeters. ...You use your own cables or the included 15-foot-long five-channel flat cable to hook up your SurroundBar 50 to an AV receiver or amplifier.
Going to connect a Cable DVR, PS3, Wii, and a WDTV (or something comparable) and send to something like a Panasonic Viera TC-P54S1 54" Plasma.
Thanks in advance for any advice, MJH.
I am mainly looking for something with at least 4-5 HDMI inputs and decent power to drive this speakerbar and a midrange ($) sub, without going way overkill.
ssmike is offline
post #5 of 7 Old 01-27-2010, 12:05 PM
Quoted: 266 Post(s)
Liked: 148
Is Polk going the Bose route? I could not find specs on it. I am pretty sure you need a powered sub alongside it, or bass output will be limited.
Otherwise, I have no idea how hard it is to drive, as they list no specs. With no other information, I can only assume it will work with any receiver.
post #6 of 7 Old 01-27-2010, 05:02 PM
cornhulio's Avatar
I've heard good things about the Vizio soundbar. I wouldn't pay more than $200 for any of them.
Polk SL2000WC $3 DIY mod. Smaller the uf, the less harsh your SL2000 is.
1. SRS: .47 uf/250v mylar cap top SL2000, 1.0 2nd, 1.0 3rd, .47 bottom
2. 2.3: 1.0 middle
3. 1C: 1.0 top
4. 2B: 1.0
cornhulio is offline
post #7 of 7 Old 01-27-2010, 05:29 PM
GTarrant's Avatar
I have the Polk Soundbar 50 for my secondary system and I paired it with an HK AVR 1600. The 50 goes down to 80Hz and I currently have it paired with an older ACI Force Sub with the crossover at 100Hz. It sounds really good for what it is, I am quite pleased. Here is a link to the Surroundbar specs on Polk's site. http://www.polkaudio.com/homeaudio/s...dbar/specs.php
GTarrant is offline
Reply Soundbars
