Vizio VSB200 Soundbar - Page 32 - AVS Forum | Home Theater Discussions And Reviews
post #931 of 1019 Old 02-27-2012, 05:47 PM
TatorTot's Avatar
I have the tv speakers set to off
Is it safe to leave the subwoofer on 24/7 ,even with the tv off
TatorTot is offline
post #932 of 1019 Old 02-27-2012, 06:03 PM
Leo King's Avatar
Yep, it's OK to leave the subwoofers ON 24hrs a day except when you're away on a long vacation. Many purists left their audio systems ON all the time.
Edit: Even with the TV speakers set to OFF, try increasing the bass control on the TV like I said in previous post to see if that will help.
Leo King is offline
post #933 of 1019 Old 02-27-2012, 06:29 PM
TatorTot's Avatar
Do you use the special trusurround feature on the soundbar ?
TatorTot is offline
post #934 of 1019 Old 02-27-2012, 06:38 PM
Leo King's Avatar
No, I don't use any special effects on the sound bar. But try them, you might like them.
Leo King is offline
post #935 of 1019 Old 02-28-2012, 06:10 PM
whalers90's Avatar
i am trying to help a friend get the code for the vizio soundbar so he can do the controls from his cablevision remote UR2-CBL-CV04
he has had 2 vizio remotes break or lost and he doesn't want to order another.
i searched this thread but i wasn't sure if on page 5 (or 6 cannot remember)
if the code information given was for the vizio tv's, the 3 digits codes or if it was for the soundbar.
any help would be appreciated but after looking at the cablevision remote it only has 2 choices of tv or cbl so if there is a code how does it work without an AUX selection like my comcast remote (which by the way THANKS to this thread, it helped me control my vizio soundbar from my comcast remote MUCH MUCH APPRECIATION!)
again any help would rock! thanks in advance.
whalers90 is offline
post #936 of 1019 Old 03-01-2012, 09:49 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Got my wife the vsb 210 from tiger direct last year for 170 and she thinks it sounds great with the sub. I don't know how she has the sound settings on it but because she is happy with the it I just ordered another this morning for my new man-cave.
Phil17108 is offline
post #937 of 1019 Old 03-15-2012, 08:03 AM
yragha's Avatar
I too bought the Sony sub, some questions however -
1. It states to plug the sub into a wall outlet, can these not be plugged into a surge protector?
2. Phase control on the back of the sub, normal or reverse?
3. It says to make sure the voltage selector is set correctly but I can't find one?
Your help would be appreciated.
yragha is offline
post #938 of 1019 Old 03-15-2012, 08:53 PM
TatorTot's Avatar
1-i have mine in a monster power surge
2-i dont know set it to which ever sounds better to you, mine is in normal
3- i put this at 50% im not sure what it does,this is located in the back of the sub is a knob u turn
Theres 2 in the back , one for the bass and the other for voltage
TatorTot is offline
post #939 of 1019 Old 03-17-2012, 04:40 PM
Leo King's Avatar
Phase control setting: Play some music with plenty of bass then switch the Phase Control to the Normal position then Reverse position. Depending on the location of the sub in the room, use the setting that gives more bass.
Your Sony sub does not have a voltage selector as it's made for the 110V power.
Leo King is offline
post #940 of 1019 Old 03-19-2012, 10:08 PM
scooby8611's Avatar
Any opinions on which of these two subs would be the best for the vizio soundbar?
http://www.amazon.com/Sony-SA-W2500-...hu-rd_add_1_dp
http://www.amazon.com/Polk-Audio-10-...2216546&sr=1-1
scooby8611 is offline
post #941 of 1019 Old 03-19-2012, 10:59 PM
TatorTot's Avatar
I have the first one
The reviews on amazon & here people say it works great
TatorTot is offline
post #942 of 1019 Old 03-20-2012, 07:11 AM
cadolfan's Avatar
I have an earlier model of the Sony. It works great.
cadolfan is offline
post #943 of 1019 Old 03-20-2012, 01:36 PM
Leo King's Avatar
I bought a Sony SA-W2500 for my girlfriend last year. If I don't already have the AR 8" sub, I would buy another SA-W2500 for myself. It's a perfect match for the VSB200.
Leo King is offline
post #944 of 1019 Old 03-21-2012, 01:39 PM
TatorTot's Avatar
Is this still the best soundbar for the price under $100 ?
Its a few years old by now right
TatorTot is offline
post #945 of 1019 Old 03-22-2012, 12:54 PM
Leo King's Avatar
Yep, if you don't need to have the HDMI connection.
Leo King is offline
post #946 of 1019 Old 03-25-2012, 09:46 AM
Bryson777's Avatar
I can't have a subwoofer at my place because of my neighbors but for a soundbar only system, god damn this thing kicks ass! And I managed to pick it up at tigerdirect for under $80 refurb. I use it to watch movies, play games and listen to music. It's going to be a sad day when this thing bites the bucket which hopefully won't be anytime soon.
Bryson777 is offline
post #947 of 1019 Old 03-27-2012, 06:05 PM
Jack Gambino's Avatar
Tip: If your remote sensor stops working...
My soundbar stopped recognizing my remote. Thought it was the battery...nope, since I tried my TV remote (which can operate the soundbar)...same problem. I gave up. It's not the end of the world, but it is a bit of a pain to use the buttons on the soundbar to control it.
I thought "too bad the soundbar doesn't have a reset button". But of course, you can unplug it, so I tried that. Waited a few seconds, plugged it back in, tried the remote and ... it works!
Jack Gambino is offline
post #948 of 1019 Old 04-12-2012, 12:32 PM
kevinhirsh's Avatar
Hello,
I am considering the Vizio VSB200 and had a question regarding its placement. I currently have my 46" LED TV on an IKEA unit (pictured below) with two shelves typically used for the cable box, dvd player. etc. Would it be okay to use one of those shelves to house the sound bar? Or will it inhibit the sound in some way?
kevinhirsh is offline
post #949 of 1019 Old 04-12-2012, 01:03 PM
Leo King's Avatar
I never have problems with the remote sensor of the VSB200.
Originally Posted by kevinhirsh View Post
Hello,
You can use the top shelf for the sound bar.
Leo King is offline
post #950 of 1019 Old 04-12-2012, 02:26 PM
kevinhirsh's Avatar
Thanks...to be clear, you mean the actual shelf, not the surface where the TV is on.
post #951 of 1019 Old 04-12-2012, 05:35 PM
TatorTot's Avatar
If your tv is as high as that one in the pic , u can put the soundbar in front of the tv
Or on the first shelf
TatorTot is offline
post #952 of 1019 Old 04-13-2012, 11:22 AM
Leo King's Avatar
Right and you might need to remove the two mounting brackets on the sound bar to make it lower.
Leo King is offline
post #953 of 1019 Old 05-28-2012, 08:49 PM
FreeBaGeL's Avatar
Does anyone else have problems with this thing just shutting off on its own while in use?
I have mine hooked up to a WDTV Live Plus via optical. I think what's happening is that the VSB200 is detecting that part is too loud and shuts itself off to protect the speakers. Is that something that's built into this unit? If so the thing is pretty useless to me as the volumes it shuts down as aren't that much louder than the built-in speakers on my cheapy 32 inch LCD.
Also, I've noticed that sometimes when I have a Dolby Digital source the VSB200 will just make a static pop and then shut off as soon as the audio source comes on (no matter the volume). These are usually the same sources where the VSB200 shuts down on its own sometimes when the stereo track is selected (usually on Netflix)
XBL & PSN: Vcize
Hit me up on XBL if you're going to be playing CoD Ghosts or the PS Vita
FreeBaGeL is offline
post #954 of 1019 Old 06-06-2012, 06:41 PM
roberteyewhy's Avatar
Just got this soundbar. Connected with the Amazon basics digital optical cable. Plugged it into my Panny Plasma TC-P42ST30 using the digital out. Turn off the speakers on the TV. Change the input on the Vizio to channel 6 (S/PDIF). Configure my Harmony 1100 to use the Vizio for the Cox/Cisco cable box and my Panny DMP-BDT210. All good to go!
Much better than the Panny speakers. Got this as a refurbished unit from Tiger Direct for $60 but looks brand new.
Robert
roberteyewhy is offline
post #955 of 1019 Old 06-15-2012, 12:00 AM
migunner's Avatar
I installed mine refurbished 69.00 bar with toslink optical for my 42" Panasonic plasma, am happy with the thing but I voided my warranty by taking it apart and drilling vent holes top and bottom in the amp compartment and enlarged the ones in back so the amp does not get so hot, I thing I am going to change the fequency capacitors to bring up the treble some, it's a little to bassy' for my ears, but in general it works very well for the price, maybe i will make a three setting circuit with switches so I have control over the output frequency, then I will find a bass speaker for it. i have a optical to analog already hooked up to my stereo so i can really rock old time with pandora,,cool.gif
migunner is offline
post #956 of 1019 Old 06-15-2012, 12:08 AM
migunner's Avatar
I took the front cover of mine and tore the foam off the leds and cut some off the plastic away from the infrared eye area so teh remote works from farther angles, and now the leds are nice and bright:cool:
migunner is offline
post #957 of 1019 Old 06-15-2012, 12:09 AM
migunner's Avatar
migunner is offline
post #958 of 1019 Old 06-30-2012, 06:07 PM
gmhall's Avatar
I've had this sound bar for about a year. A few weeks ago it started cutting out intermitently once it's been on an hour or so. The blue indicator lights flicker for about 10 seconds, then it comes back on. The error codes indicate this is an overheating problem. Disappointed. Anyone know a fix?
gmhall is offline
post #959 of 1019 Old 07-01-2012, 03:23 PM
steve1022's Avatar
Quoted: 81 Post(s)
Liked: 65
There really haven't been any reports of failures but now that it has been out for a while I'm sure we will start hearing more about failures. I don't have any recomendations aside from suggesting to check if there is a reset button somewhere on it (possibly under the foam cover by the led's?)
PSN: ROLL_mf_TIDE
steve1022 is offline
post #960 of 1019 Old 07-14-2012, 09:23 PM
wjason's Avatar
I recently bought a Vizio VSB200 (refurbished). Seems that's all I see now--perhaps Vizio has stopped making them. Anyway, I bought before I researched. Turns out, the VSB200 accepts only PCM digital audio input and my tv (LG 42LH30) outputs only AC3 and cannot be made to output PCM (I called the LG support line). It also has no RCA (analog) outputs.
In college, I had a text book that began, "The nice thing about standards is there are so many to choose from." Silly me--I thought digital optical audio was digital optical audio. Alas, not true.
Anyway, Grefen makes a digital-audio-to-analog converter (which costs more than I spent on the VSB200) and it accepts only AC3 input. The odd thing is, when I stream certain shows from Netflix, they play sound on the VSB200 (which sounds great, BTW). Others do not. Broadcast (OTA) TV does not produce sound on the VSB200. Some shows streamed from Netflix (like Star Trek TOS) will produce sound from some episodes, but not others. How can a TV, which I'm told cannot output PCM, apparently put out PCM when connected to Netflix? Will the Grefen still work if I stream a show from Netflix that is putting out PCM? Confused? Me too.
Anyway, my question is, do I spend more money on the converter from Grefen? Or sell the soundbar to someone who has analog output from their TV?
Also, I've looked at the specs for a lot of other soundbars and almost none of them say whether they accept AC3 or PCM, or both (or perhaps there is yet another digital audio format I'm unaware of?) They all say whether there is a digital optical audio input jack--but this incident has taught me that this is insufficient information. Are there any soundbars on the market that accept AC3 input? Or, ideally, will switch automatically between multiple digital audio formats? How can you tell without calling each manufacturer?
wjason is offline
Reply Soundbars
