Boston A vs Sony Soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-08-2009, 02:12 PM - Thread Starter
cropduster330's Avatar
Well I know how much alot of you like the Sony HT-C100, but after hearing it I was a bit turned off by the volume capability. I am not one looking for something to shake the house, but I had it turned up to max volume on the sub and it just didn't seem to have much.
Conversely, the Boston Acoustics 2.1 TVEEM2B-01 seemed to have a much more powerful sound, but nobody on these forums talk much about this soundbar.
I am a newbie at this, and am just trying to find a reason other than the connectivity why I should'nt go with the Boston.
Any help greatly appreciated, thanks!
cropduster330 is offline
post #2 of 5 Old 07-08-2009, 04:06 PM
cupfulloflol's Avatar
It isn't surround sound, so if you want the sense of sound coming from multiple directions you won't get it with the B.A. . Which is why it has the connections it does, or lack of them rather. Although from the looks of it, according to a quick google search it only has one input. Not a huge deal, but it would be a dealbreaker for me. Basically you would have to connect everything to your TV, then have audio out (headphones maybe) to the soundbar.
But if you have auditioned them, go with the one you think would make you happier. You don't have to please us, you have to please yourself, and your wife/kids or whatever. Different people have different wants and needs. Some people will say speaker A is the best speaker in the world, while others will say speaker B is while talking bad about speaker A....etc As long as the main people listening to it are happy, that is the important part.
cupfulloflol is offline
post #3 of 5 Old 07-09-2009, 01:06 AM
davyo's Avatar
As a soundbar junkie (had a Sony CT-100 and bunch of YSP's, now have the CT-500) I have been wondering what the Boston soundbar sounds like as they do make some very good products.
I have been to my local BestBuy a few times but so far they dont have a display model set up so I have not been able to give a listen yet.
Me thinks next time I go to BB I shall ask them to set one up.
Cheers
Davyo
davyo is offline
post #4 of 5 Old 07-09-2009, 08:31 AM - Thread Starter
thanks for the replies, again. one more thing, i see people mentioning the Boston is a "speaker system", does this Boston require an amp?
also, it's only listed at 100 W, does that seem really low?
post #5 of 5 Old 09-17-2009, 03:49 PM
kopaunum's Avatar
by far for me the BA sounds far better than the sony soundbar. It just had more ooomph to it than the sony. I kind of don't care about whether it has more connections or more surround sound capability, I just base it on what I hear and hearing both soundbars side to side at BB, the BA is FAR superior IMO.
kopaunum is offline
Reply Soundbars
