Best way to hook up sound bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-09-2009, 01:56 PM - Thread Starter
cropduster330's Avatar
Sorry I have had so many newbie questions, but here is another, and it is quite simple. I think.
If I have a soundbar with strictly one RCA input connection and assumming I am not dealing with a DVD player, MP3, or anything of the sort, do I run the two RCA cables from my digitial cable box to it or from my plasma to it?
Once again, just cable box-plasma-soundbar and nothing more
thanks all...
cropduster330 is offline
post #2 of 6 Old 07-09-2009, 02:35 PM
m_vanmeter's Avatar
you could try feeding the soundbar with the red/white analog output from the TV. That way if you do hook a DVD player or game to the TV, the sound will be fed to the soundbar. Some TV's will pass through any input audio to the analog stereo output terminals.....but some will not, they will only pass the audio from the interal over-the-air tuner.
If, as you stated, you are only worried about the programming from a cable box, run the audio from the cable box to the sound bar
m_vanmeter is offline
post #3 of 6 Old 07-10-2009, 08:26 AM - Thread Starter
thanks for the reply, could I also get some sort of a A/V switcher to toggle between the cable box and a DVD player?
post #4 of 6 Old 07-10-2009, 09:14 AM
vinipux77's Avatar
Yes, you could, but why overcomplicate the setup if TV can do all the switching?
vinipux77 is offline
post #5 of 6 Old 07-10-2009, 09:34 AM - Thread Starter
thanks, you are correct... but maybe I should have been more specific...an ipod via a Y cable, then I suppose I would need a seperate switcher?
post #6 of 6 Old 07-10-2009, 10:44 AM
vinipux77's Avatar
I guess, but then it's best to use a pre-amp with things like iPod, unless you can tap into line-out on the iPod.
Reply Soundbars
