Sony Sound Bar Blocks TV IR Sensor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-19-2009, 04:31 PM - Thread Starter
gtszbaii21's Avatar
Ok so i want to get the Sony sound bar HT-CT100. I have measured it and if I place it on my LCD tv's pedestal, it will block the IR sensor. I have a Toshiba Regza 42" 1080p HDTV. Should I just put the sound bar on the tv stand on the first shelf? Also please don't suggest mounting everything on the wall because I can't. Any suggestions on what I can do here? Thanks.
gtszbaii21 is offline
post #2 of 2 Old 07-19-2009, 05:16 PM
ceiph's Avatar
i know the ct-100 has its own thread so they may have a better answer but as long as the bar is on the ledge and not enclosed i would think your fine
ceiph is offline
Reply Soundbars
