L/C/R Sound bar reccomendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-23-2009, 09:51 PM - Thread Starter
Show1's Avatar
I have a spacious bedroom that I'm finishing up. Putting in a Panasonic 54V10 plasma on the wall and looking at a Left/Ctr/Right sound bar solution to put under it.
I've got a Yamaha RX-V765 receiver for power, and was looking for recommendations for a sound bar that will play well in the space(14' x 20'). I plan on putting in two rear speakers and a separate sub and looking for what other members might have done along this line? Have up to $2.5k for budget on the combo of sound bar, rear surrounds and sub.
I saw Monitor Audio has a Radius One LCR sound bar that looked interesting. I have the Silver series RS-6's in my theater and I like those. Any advice/other endorsements appreciated!
Will Detail Later
Show1 is offline
post #2 of 14 Old 08-23-2009, 10:43 PM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
Triad
http://www.triadspeakers.com/products/owmlcr3.html
Can be ordered in different widths to match tv in 1/4" increments.
Can also be painted.
Triad also makes matching in-wall, in-ceiling, on-wall or bookshelf type speakers for rears. As well as in-wall or regular subwoofers.
Here is a 50" Panasonic with Triad LCR
ifor is offline
post #3 of 14 Old 08-23-2009, 10:57 PM - Thread Starter
Show1's Avatar
Thanks, ifor, didn't know Triad had this model.
Will Detail Later
Show1 is offline
post #4 of 14 Old 08-24-2009, 01:26 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
They have the standard 3.0LCR as well as a 3.0LCR S.E. with better drivers. But to keep within your budget, I'd stick to the standard version.
And I haven't heard anything that can match it.
ifor is offline
post #5 of 14 Old 08-24-2009, 06:44 AM
jzoz01's Avatar
Leon Horizon series LCR. Matches the exact width of the panel, as well as the finish. Available is driver sizes ranging from 2" - 7".
jzoz01 is offline
post #6 of 14 Old 08-24-2009, 06:49 AM
ttowntony's Avatar
+1 +2 +3 on the Triad.
Tony G. Cordova, President
Showplace Oklahoma - Showplace Theater & Sound
"We put the SHOW in your PLACE."
ttowntony is offline
post #7 of 14 Old 08-24-2009, 01:20 PM - Thread Starter
Show1's Avatar
Thanks for the tips, folks.... Also saw Atlantic technology had the FS-5000 model but gonna have to check out the triad versions. Also liked that they had sealed in ceiling surrounds to match with their sound bar.
Will Detail Later
Show1 is offline
post #8 of 14 Old 01-30-2010, 01:33 PM
DRobStL's Avatar
I'm in a similar situation to that of the OP. I'm adding surround to my first floor tv room, which has a 52" LCD above the fireplace, and has one large opening to the adjoining room on the right wall perpendicular to the tv, and an irregular stairwell opening on the wall opposite the tv.
There are in-wall surround speakers already, and I've got 3 sets of speaker wires coming out of the wall behind the tv, along with an HDMI cable. I can't run (without unacceptable expense) any more wires from my components to the tv, so a powered soundbar is not an option.
I mostly watch tv (predominately sports), with the occasional blu-ray. I don't really listen to music. So, top-of-the line speakers are probably excessive for me. In addition to the soundbars noted above, I also know about the Canton CD 90 SB ($650 msrp). Does anyone know if this is a good speaker?
I'm surprised at how hard it is to find 3-channel surround bars for under $1000. Does anyone know of any others?
Given the difficulty I'm having finding a 3-channel bar appropriate for my needs, I'm also considering the Polk Surroundbar 50 and the Def Tech SSA-50 (which can be had for under $1000). I would feel a little foolish buying a 5-channel bar and only using 3 of the channels, but it's possible I could use a 5-channel bar in the future, and if a 5-channel gives good sound and is cheaper than a 3-channel, that may be the way to go for me.
I'd be interested in people's thoughts on using 3 channels on a 5-channel bar instead of a 3-channel bar (and also recommendations for any other brands/models of unpowered soundbars).
DRobStL is offline
post #9 of 14 Old 01-30-2010, 02:00 PM
ickysmits's Avatar
Aside from the ones mentioned above:
Atlantic Technology FS4000 & FS5000
Pinnacle Speakers makes one.
Mirage Uni-theater
I wouldn't deviate from the way the Polk or the Def Tech were intended to be used.
ickysmits is offline
post #10 of 14 Old 01-30-2010, 02:55 PM
Chicagorep's Avatar
Leon, they will make it to your exact specs.
Chicagorep is offline
post #11 of 14 Old 01-30-2010, 10:22 PM
DRobStL's Avatar
Very nice-looking setup. Can I ask how much that Leon speaker cost? I understand Leon offers customization; I'm just looking for a ballpark figure to see if this may be appropriate for me.
DRobStL is offline
post #12 of 14 Old 01-30-2010, 10:24 PM
cornhulio's Avatar
I would try to listen to the Vizio. I've seen several positive feedbacks on it and afaik it's a lot cheaper. None of them can replace or imitate a 5.0 setup but they are better than the TV speaker.
Polk SL2000WC $3 DIY mod. Smaller the uf, the less harsh your SL2000 is.
1. SRS: .47 uf/250v mylar cap top SL2000, 1.0 2nd, 1.0 3rd, .47 bottom
2. 2.3: 1.0 middle
3. 1C: 1.0 top
4. 2B: 1.0
cornhulio is offline
post #13 of 14 Old 01-31-2010, 08:17 AM
DRobStL's Avatar
Unfortunately, because of my wiring situation, a powered soundbar won't work for me.
Does anyone have experience with Dayton speakers? The Dayton BS36 at parts-express.com looks like it would fit my need. But, it is so much less expensive that the other entries in this field, and I wonder what the reason is.
DRobStL is offline
post #14 of 14 Old 02-01-2010, 07:04 AM
jzoz01's Avatar
Every Horizon speaker is custom built to order to match the exact width and finish of any flat panel display. In LCR configuration, they start at $1,295 MSRP. All speakers are hand built in Ann Arbor, Michigan in just 5 business days.
jzoz01 is offline
Reply Soundbars
