Sony HT-CT150 and CT350 - Page 71 - AVS Forum | Home Theater Discussions And Reviews
post #2101 of 2119 Old 07-25-2014, 01:49 PM
JackN's Avatar
Quoted: 38 Post(s)
Liked: 24
Originally Posted by Streifer View Post
So, in other words, there is no such thing as Prologic II encoding. Instead, if you use Handbrake, for instance, to transcode or rip a video to have a Prologic II audio track, all Handbrake is doing is adding info or flags that tell the receiver to decode the 2-channel audio track as a multi-channel audio track (i.e, simulate a surround track)?
That would explain why my receiver shows LPCM whenever it plays a ProLogic II track.
I'm a little out of my depth on this one (DaverJ has more on the encoding question above). I was coming at this from the standpoint of reading that PLII could be applied to any two channel source and watching how the CT-100 handled various signal types; my experience with PLII has always been in the post-processing realm.
I had one case where a Dolby 1.0 track was, disappointingly, coming out of the center channel only. So I set my dvd player to output PCM, which arrived at the CT100 as a 2 channel, L/R mono signal...which was then "eligible" for the ProLogicII process (meeting the 2 channel requirement for PLII). I kicked the 100 into MOVIE mode, the unit reported "PCM" with PLII in play...and a previously very thin sounding track was now being processed into fake surround with a much stronger low end. I'm not sure every DVD or Blu-ray player would ouput Dolby 1.0 as 2 channel PCM in PCM mode, but it's worth a shot if you ever get saddled with the dreaded DD 1.0 scenario.
In addition to 2 channel PCM tracks, you should also be able to see PLII engage for 2 channel Dolby sources on your 150 in any of the modes where PLII is supported.
JackN is offline
post #2102 of 2119 Old 11-19-2014, 07:38 PM
iamloco724's Avatar
Quoted: 16 Post(s)
My hdmi cable went bad that was connected from my cable box to the 150 sub i changed it and now i lost my connection between the two with my remote i use to use my cable remote for everything except for changing inputs
I dont remember if i had to do anything special to get this to work right i set it up 3 years ago and havnt had an issue had a bad cable today put the new cable now i cant do anything with the cable remote it only controls the tv doesnt control the soundbar volume like it did and wont turn on both together like it did
how do i get this to sync back up?
iamloco724 is offline
post #2103 of 2119 Old 11-20-2014, 03:26 PM
dwong's Avatar
Try it with other HDMI ports, if other ports got no issue then you might have a bad port now.
I see the atoms free and fine,
That bubble like a sparkling wine;
I see the songs Electrons sing,
Jumping from ring to outer ring;
              - Lister, The Physicist
dwong is offline
post #2104 of 2119 Old 11-20-2014, 03:28 PM
iamloco724's Avatar
Quoted: 16 Post(s)
the port works fine since i replaced the cable i can view the source and have sound, i would think if its bad none of that would work, i assume if the port was bad i wouldnt just have this remote issue
post #2105 of 2119 Old 11-21-2014, 12:06 AM
dwong's Avatar
If you know the port work fine, then your Sub unit went bad. You can't fix hardware failures.
dwong is offline
post #2106 of 2119 Old 11-21-2014, 12:09 AM
iamloco724's Avatar
Quoted: 16 Post(s)
But how would the sub be bad if everything works except for my cable remote no longer being able to control the system
post #2107 of 2119 Old 11-21-2014, 10:19 AM
dwong's Avatar
If the sub can't receive any remote signal...
dwong is offline
post #2108 of 2119 Old 11-21-2014, 11:06 AM
iamloco724's Avatar
Quoted: 16 Post(s)
It does receive a remote signal just not the remote I have been using for 3 years it receives the signal from the remote that came with the unit
post #2109 of 2119 Old 11-21-2014, 01:40 PM
dwong's Avatar
Then try read your manual on remote programming, usually there is a 3 or 4 dig code for Sony brand devices in the back of manual.
dwong is offline
post #2110 of 2119 Old 11-21-2014, 02:39 PM
iamloco724's Avatar
Quoted: 16 Post(s)
my fios remote doesnt have any codes for devices other than tvs and i didnt have to do that when i installed it 3 years ago
post #2111 of 2119 Old 11-21-2014, 04:06 PM
dwong's Avatar
If devices not broken, then you must did something, LOL.
Maybe your box's audio output is on 'fixed', try change to 'variable'. etc.
dwong is offline
post #2112 of 2119 Old 11-21-2014, 04:11 PM
iamloco724's Avatar
Quoted: 16 Post(s)
i tried both variable and fixed no difference since its not the box volume im trying to change
only thing i did was switch that bad cable
the problem is when i switched it i think this happened
this is in the manual
"The system is not turned on when you turn
the TV on if sound was being output from
the TV speakers the last time the TV was
turned off"
so i think when the cable went bad i had turned the tv off with the tv speakers playing the sound, but it doesnt say how to correct this and ive tried every scenario possible, i really dont get it its so frustrating
post #2113 of 2119 Old 11-22-2014, 10:24 PM
dwong's Avatar
With user error, all you can do is read all the manuals carefully and double check each setting.
Unplug everything and start from scratch might helps, good luck.
turned off"
dwong is offline
post #2114 of 2119 Old 09-21-2015, 05:29 AM
SRIBB43's Avatar
I have an issue with my 150. I have my Blu-Ray, DTV box connected to the sub and then a HDMI going from the ARC input to my tv. Whenever I power on my tv and DTV box, the input on the sub is "SAT-Cable" in which I get my audio but then after a few seconds it switches to "TV" in which I get no audio. So I am having to manually adjust the input back to "SAT-Cable" every time I turn on my tv.
I had this issue when I first connected everything a few years ago and was able to fix but I moved recently and had to reconnect stuff and now I'm back in the same boat but can't remember the solution
SRIBB43 is offline
post #2115 of 2119 Old 01-10-2016, 05:36 AM
chrpai's Avatar
I've had this sound bar for about 5 years now and only recently hooked it up to a smart TV. I like the HDMI ARC functionality a lot. The TV controls the sound bar so I don't need any IR codes in my remote or use the HDMI switch on the sound bar anymore. The TV runs the show nice and easy.
It makes me wonder though. Has anyone ever used this to drive other speakers? I'm thinking about leaving the speaker bar mounted above the TV for the center channel only but putting left and right speakers on the wall. Does anyone this this would be an improvement? It looks like I'd need 4 ohm speakers.
chrpai is offline
post #2116 of 2119 Old 01-10-2016, 07:24 AM
bigcat's Avatar
Quoted: 104 Post(s)
I am curious about this too. I have the HT-CT550W though. The back of the receiver does not have "ports" for other speakers, not sure how that would work.
BenQ W1070/Silver Ticket 120"/Denon X4200W/Infinity Primus | Vizio 80" 3D LED M801D-A3 w/ Denon X3200W/Infinity Primus | Sony Bravia XBR-60LX900 w/ Sony HTCT550W 3D Sound Bar | Sony SXRD KDS-R70XBR2 w/ Onkyo HT-S770 | Sony PS3 (Slim) | DIRECTV Genie HR44-500, C41s | Harmony 700
bigcat is offline
post #2117 of 2119 Old 05-15-2016, 12:13 PM
JPHCCFC's Avatar
Quoted: 29 Post(s)
Does the ht ct150 support hdmi2.0 4k 60fps through passthru?
JPHCCFC is offline
post #2118 of 2119 Old 05-17-2016, 04:53 PM
Tuan's Avatar
Quoted: 14 Post(s)
Send a message via Skype™ to Tuan
No. It was released before HDMI 2.0 was even a spec.
Tuan is offline
post #2119 of 2119 Old 09-05-2017, 08:37 PM
boltjames's Avatar
Quoted: 56 Post(s)
I'm the owner of a HT-CT150 and am about to upgrade my HDTV to 4K, just landed hear to find out the bad news that it's not compatible.
In light of this, can someone recommend a system like this one that is 4K compatible? Key features being:
1. The home theater receiver designed in the form factor of a subwoofer (all HDMI cables need to go in/out of the sub not the soundbar).
2. At least 3 HDMI inputs and all with the 4K spec as I need this home theater soundbar/sub to handle all the HDMI switching).
3. Wired soundbar is a plus (would prefer not to deal with Bluetooth or other technologies).
In layman's terms, I would keep my CT150 and be happy as a clam if it supported 4K. Just looking for something as simple and basic as a direct replacement.
boltjames is offline
Reply Soundbars
