Pioneer HTP-SB300 Soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 03-22-2010, 08:49 PM - Thread Starter
l3ftonm3's Avatar
Has anyone had a chance to listen to one of these yet? I searched and couldn't find anything about it on here. It's a 3.1 soundbar with wireless sub and it supports Dolby TruHD and LPCM.
http://www.pioneerelectronics.com/PU...300.Kuro?tab=A
Reviews
http://www.trustedreviews.com/home-c...00-Soundbar/p1
http://reviews.cnet.co.uk/accessorie...9305278,00.htm
http://www.pocket-lint.com/review/46...oundbar-review
I see two places in the states selling it now online. Hopefully someone can chime in.
l3ftonm3 is offline
post #2 of 35 Old 03-23-2010, 10:56 PM - Thread Starter
l3ftonm3's Avatar
It seems like the product is just hitting the US market so it's too new for anyone to have an opinion on it yet. Hopefully someone picks one up soon and posts a review as it seems to be a great option in the $350 and under soundbar market. If I find anymore info I will post it here.
l3ftonm3 is offline
post #3 of 35 Old 04-03-2010, 09:31 PM
qposner's Avatar
Quoted: 17 Post(s)
I would like some info on this SB as well. Thanks for the tip!
qposner is offline
post #4 of 35 Old 04-04-2010, 06:04 AM
trich's Avatar
I've been waiting for Pio or Panny to come out with a SB for my two plasmas. It looks like Pioneer was first so I'm going to order one today $289. It has all the things that I want. I just hope the sound is as good as the Vizio I had. I hated the remote on the vizio.
Bobby Ray
trich is offline
post #5 of 35 Old 04-04-2010, 07:01 PM - Thread Starter
l3ftonm3's Avatar
From what I have read the remote isn't the greatest as its quite cluttered. But this wouldn't be a concern for me since I plan to pickup a Logitech Harmony 650 or 300.
l3ftonm3 is offline
post #6 of 35 Old 04-05-2010, 04:18 PM
trich's Avatar
My Pioneer HTP-SB300 Soundbar was shipped today from Buy.com
Bobby Ray
trich is offline
post #7 of 35 Old 04-05-2010, 07:27 PM - Thread Starter
l3ftonm3's Avatar
I await your review and hopefully some pictures. There is only 3 stock pictures that I can find. If you could take some pictures of the back of the speaker and a picture of the front of the speaker with the grill off if thats even possible that would be great.
l3ftonm3 is offline
post #8 of 35 Old 07-13-2010, 10:00 PM
agpatel's Avatar
Any update on this soundbar and how it sounds? How is the wireless sub and any major interference with it.
agpatel is offline
post #9 of 35 Old 07-14-2010, 07:42 AM
maniti2005's Avatar
I would also like to know how it sounds as well before I make my purchase..
maniti2005 is offline
post #10 of 35 Old 07-14-2010, 02:33 PM - Thread Starter
l3ftonm3's Avatar
I have not been able to find many reviews about it except for what I posted above. The most recent reviews and opinions are all in Japanese.
l3ftonm3 is offline
post #11 of 35 Old 08-18-2010, 02:30 PM
EKinNYC's Avatar
has anyoen received theirs yet? curious to hear feedback
EKinNYC is offline
post #12 of 35 Old 08-19-2010, 12:25 PM
nclee's Avatar
Received mine on last Sat. hook up was easy. Will spend more time this weekend to play with it. Bought it from Amazon.
nclee is offline
post #13 of 35 Old 08-19-2010, 12:59 PM - Thread Starter
l3ftonm3's Avatar
Let us know what you think. There needs to be more opinions available for review with this model.
l3ftonm3 is offline
post #14 of 35 Old 08-21-2010, 02:36 PM
nclee's Avatar
I have the Pioneer hooked to direct tv on HDMI2, LG bluray 570 on HDMI1, and HDMI out to LG 50PK750 plasma HDMI1 input. Iit sits right in front of the plasma. (Before the sound bar arrived, both were hooked up to the plasma directly, direct tv on HDMI1, 570 on HDMI2).
Since this is my first time using a sound bar. I can't compare to other brand.
It does do the following just like Pioneer advertised,
recognize Dolby True HD, and other Dolby processing
only recognize regular DTS, not HD
How is the sound? Way better then the TV set. Is it worth the money. Definitely (to me). Would it replace a proper 5.1 set up? NO.
I played a few movies, the latest Star Trek, 300, Harry Potter. Even though the sound field is not that wide, but it definitely is there.
nclee is offline
post #15 of 35 Old 08-21-2010, 06:17 PM - Thread Starter
l3ftonm3's Avatar
It should also support LPCM from what I read. So not having DTS-HD is annoying but not necessary either.
l3ftonm3 is offline
post #16 of 35 Old 08-21-2010, 09:10 PM
EKinNYC's Avatar
how is the sound quality and the processing? from reading other reviews in the links posted by OP, it seems that as soon as the surround sound processing is turned on, the sound becomes metallic and "fake" sounding
EKinNYC is offline
post #17 of 35 Old 08-23-2010, 06:47 AM
nclee's Avatar
I mostly use pure direct to watch movies (to me it sounded the best), and when the volume is set to 30 (don't know how much higher it will go), it was very loud to me.
I did try a few sound processing, like action, drama etc, it does add some extra effect to the sound, would I describe it as metal or fake. I guess you can say it added a little, but it is not tiresome or annoying.
nclee is offline
post #18 of 35 Old 08-23-2010, 10:21 AM - Thread Starter
l3ftonm3's Avatar
Were you able to notice the 3 different channels during use? Or did they just blend together? Is there options to adjust the center channel gain and L/R gain?
l3ftonm3 is offline
post #19 of 35 Old 08-25-2010, 07:04 PM
nclee's Avatar
since I only use HDMI, I can't do (or I'm not aware of) L/R grain etc.
nclee is offline
post #20 of 35 Old 08-25-2010, 08:08 PM - Thread Starter
l3ftonm3's Avatar
Any chance you can take a few pictures and post them on here?
l3ftonm3 is offline
post #21 of 35 Old 08-26-2010, 07:27 AM
EKinNYC's Avatar
hows the quality of the passthru picture for your components?
has anyone tried to program it with a Harmony remote? just want to make sure i can macro the component switching.
i still cant decide if i want this SB for the hdmi switching/truHD decoding, or just go with a vizio/jvc/polk/boston acoustics and use it as a pure soundbar and forget about surround/decoding.
EKinNYC is offline
post #22 of 35 Old 08-30-2010, 06:37 AM
nclee's Avatar
I have no idea how to post picture. I tried to include it in the message, but it ask me of a URL link....
nclee is offline
post #23 of 35 Old 08-30-2010, 03:22 PM - Thread Starter
l3ftonm3's Avatar
You can upload them to
http://imageshack.us
Then just copy and paste the forum code it lists under the links section.
l3ftonm3 is offline
post #24 of 35 Old 09-10-2010, 01:16 PM - Thread Starter
l3ftonm3's Avatar
I found another review but its in German. Google doesn't seem to be able to translate the page for some reason so if someone can get it to work that would be great.
http://www.netzwelt.de/news/83848-pi...p-sb-300-video
It does have a video which gives you a good view on how it looks compared to all the stock photos on the web.
l3ftonm3 is offline
post #25 of 35 Old 10-08-2010, 12:45 PM
EKinNYC's Avatar
just wanted to bump this to the top to see if anyone else has purchased this unit and wanted to post a review
EKinNYC is offline
post #26 of 35 Old 11-05-2010, 04:50 PM
Heart of Dixie's Avatar
I am strongly considering getting one of these. Anyone else care to chime in?
Wondering why it is selling so cheap. MSRP is $599, they are selling for half that.
Davyo, any opinions?
I love this forum! Been reading for months
Heart of Dixie is offline
post #27 of 35 Old 11-06-2010, 12:05 AM
vjcs20's Avatar
Any recent reviews?
vjcs20 is offline
post #28 of 35 Old 11-08-2010, 10:53 PM
klas's Avatar
Just ordered one from the store where I never ever shop with one exception... Upgrading from Sony CT100 which ironically I purchased from the same store 3 years ago. This pioneer unit has everything I need, 2x HDMI, wireless sub and sleek looks, hopefully sound quality doesn't disappoint, although I've been perfectly satisfied with CT100 which by all means not the best one.
EDIT: I've been researching the manual and I could not find any information whether the system allows adjusting the sub volume. Is it true, or is there some hidden feature that's not listed in the manual?
http://www.pioneerelectronics.com/St...uction0119.pdf
Mac Mini HTPC (Win7)
klas is offline
post #29 of 35 Old 11-09-2010, 04:37 PM
klas, let us know how it goes once you get the Pioneer. I will probably buy this unit in the next few weeks.
I hadn't thought about the sub level .Iwould imagine that it could be adjusted.
post #30 of 35 Old 11-09-2010, 04:54 PM
klas's Avatar
I did not find anywhere in the manual about subwoofer level adjustment. As a matter of fact one of the reviews state that subwoofer is a bit overpowering in music which something I am a bit worried about.
Verdict:
It's not great with music either, as the sub is a little too overpowering, but because the soundbar doesn't have the bass depth to cope on its own it's a bit of a Catch 22. Overall it's no disaster, but not quite up to the standard of soundbars from the likes of B&W and Teufel.
klas is offline
Reply Soundbars
