Went to Target and tried to buy a Vizio soundbar. There was a - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 07-21-2010, 06:42 PM
hotroddr32's Avatar
Well, my Target only had one. So I've got it boxed up and getting my money back. It makes little difference, but the bar really sounded pretty good. I was suprised it produced the lows that it did. It still was not close to what it should have been with the sub. Maybe the next person will have better luck, but I'll try for something else.
(This was my first soundbar, so I didn't have anything to compare it to, so I have no stinking idea what to get.)
hotroddr32 is offline
post #32 of 34 Old 07-21-2010, 08:56 PM
nr5667's Avatar
Perhaps you should look into a 2.1 set up?
They're ultimately going to give you more range for the dollars spent.
The VHT210 has a 5.25" subwoofer, and a few 2.75" tweeters... That's going to be rather limited, ultimately.
I've had sound bars from Sony, Vizio, and Boston Acoustics.
I'm a bit OCD, and I like the idea of such a neat and pretty little system, but none of them have really compared to a similarly priced 2.1 system.
nr5667 is offline
post #33 of 34 Old 07-22-2010, 11:20 AM
Joey O's Avatar
See what happens. You people pressure Vizio to release it quickly. They rush it together and then it has problems. :-) They probably forgot a bolt or something. :-)
Joey O is offline
post #34 of 34 Old 07-22-2010, 02:36 PM
davyo's Avatar
Sorry your bar was defective,,, that does suck after the early score you made in getting it,,,,,, perhaps Vizio had the bar set to not work properly until after July 25th.
Funny !!!
But on a side note,,,, guess when this bar was spose to come out,,,, Vizio introduced it at CES during the first week in January and said it was coming out later that month,,, its now coming out just a week shy of being 8 months late.
Cheers
Davyo
davyo is offline
Reply Soundbars
