How to hook up a Vizio VSB200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-20-2010, 08:49 AM - Thread Starter
laurandavid's Avatar
I am thinking about getting this, but with no hdmi and only one optical I have a question. On my TV I have 3 hdmi connections which is enough for all of my stuff. I will have my pc (HDMI), uverse box(HDMI), blu ray player(HDMI), Wii (Hooked up component), and a dvd/vcr combo (hooked up through composite). So would I just run all three hdmi connections to the TV, and then use the optical cable to hook up the soundbar from the TV and I would be able to use the soundbar for everything I have hooked up to the TV. Also if the low end is not enoughg, I could add a sub of my choosing. If I am not happy with it, I can just return it to walmart since they take back everything.
laurandavid is offline
post #2 of 5 Old 07-20-2010, 10:02 AM - Thread Starter
Is there any other info that is needed to answer my question?
post #3 of 5 Old 07-20-2010, 11:41 AM
drfreeman60's Avatar
Liked: 52
That should work with everything connected to the television and one connection from TV to the soundbar.
David Freeman
drfreeman60 is offline
post #4 of 5 Old 07-20-2010, 12:38 PM - Thread Starter
What size room is this soundbar good for?
post #5 of 5 Old 07-20-2010, 07:36 PM - Thread Starter
Well went to pick one up at walmart. I was impressed with the sound. The only thing that bothers me is the fact there is no seperate adjustments from trebble and bass. It seemed to have a good amount of bass, but a little more would be good. It seemed the vocals were a little lower and an adjustement of the treble would work great. When I tried to use the optical to watch tv I could not, so this is a deal breaker for me. Sounded great on blu ray and pretty good job on surround sound. When I was watching TV, all I would get is a loud buzz on optical, but fine on analog. Optical has way better sound.
Reply Soundbars
