Where should I mount my soundbar? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-27-2010, 09:42 AM - Thread Starter
yoynot325's Avatar
So I just purchased the Sony 150 soundbar the other day from BB. I have it mounted on the wall below my tv, but after reading some posts, I also read that it would sound better on top of my tv. What do you guys suggest?
Thanks in advance,
ToeKnee
P.S. First post for me.
yoynot325 is offline
post #2 of 8 Old 07-27-2010, 10:09 AM
viziodood's Avatar
I have the older ct100 sony soundbar, after having it sitting both below and above my LCD i find it sounds better above.
viziodood is offline
post #3 of 8 Old 07-27-2010, 10:52 AM
Cache$$$Mustang's Avatar
The general consensus is sound bars sound much better above the TV, where the sound has more room to open up. There are a couple of methods of mounting your sound bar on top of your TV: Velcro, home-made brackets, and brackets bought off of www.soundbarbrackets.com
Here's a thread discussing various methods: http://www.avsforum.com/avs-vb/showthread.php?t=1259583
I myself just bought the new Vizio and am anxiously awaiting the sound bar brackets so I can mount it above my screen and see how much better the sounds improves.
Cache$$$Mustang is offline
post #4 of 8 Old 07-27-2010, 11:20 AM - Thread Starter
yoynot325's Avatar
Thanks guys for the reply!
post #5 of 8 Old 07-27-2010, 01:50 PM
sk8 luder 97's Avatar
You cannot use those brackets if your mounting your tv on the wall can u?
sk8 luder 97 is offline
post #6 of 8 Old 07-27-2010, 07:23 PM
davyo's Avatar
Thanks in advance,
ToeKnee
Welcome to AVS
And yes,,, above your display is always better for mounting a soundbar.
If you have a wide enough bezel on your display the Vizio can sit on top with some velcro for extra hold,,,, Ive done it and it works great.
Yes, the Vizio brackets flip around specificaly for wall mounting.
Cheers
Davyo
davyo is offline
post #7 of 8 Old 07-28-2010, 06:27 AM
CSonntag's Avatar
Quoted: 186 Post(s)
Liked: 65
Fifty bucks for a couple of bent pieces of metal? Yowza. I'd rather go buy some heavy duty metal strapping at Home Depot, and bend/drill them myself. A quick shot of flat black spray paint and you're good to go.
Take responsibility for your own actions...society is not here to look after you...
In other words, if you order coffee, expect it to be hot for christsake!
CSonntag is offline
post #8 of 8 Old 07-28-2010, 09:53 AM
Yeah it is a bit of a rip off, guess they can charge as much as they want since they don't have any competitors. I was thinking of saying I'm a patent attorney/examiner and from my IP background I respect the genius that went into the design (it is clever), but to be honest it's because I'd rather not deal with the time commitment of getting all the parts and then putting it together. Some projects I prefer to do on my own, but when it deals with home entertainment I go the easy route. Guess the ease of installation is why I went the soundbar route. That and I live in an apartment.
Adam
Reply Soundbars
