good small sound bar w/o subwoofer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-03-2010, 10:06 PM - Thread Starter
vejichan's Avatar
Hi i am looking for small soundbar or two speaker system. preferably ones with good bass and don't need a subwoofer. I don't have a big room and i am not going to crank it. Just something that will simulate a tiny theater in a tiny room with a small lcd tv.
thanks
vejichan is offline
post #2 of 3 Old 08-03-2010, 10:15 PM
mogambokhushhua's Avatar
thanks
Try and read about the zvox series they might be something that you are looking at.
mogambokhushhua is offline
post #3 of 3 Old 08-04-2010, 01:44 PM
drfreeman60's Avatar
Liked: 52
According to cNets review, the new Panasonic soundbar has good bass without sub. I have listened to Yamaha and Vizio soudbars with and without attached subs and the sound is solid on either without. The sub does give more foundation when you actually have material with true low level sounds. The idea of a good bass driver or sub-woofer should not be to make low frequencies louder or more place more emphasis on them, but to extend the low frequencies. Many of the so called sub woofers have a big hump at mid-bass (100-140hz) to make them sound boomier without really enhancing the low frequencies.
David Freeman
drfreeman60 is offline
Reply Soundbars
