Do I need a sound bar if my sofa is against the wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-02-2010, 01:47 PM - Thread Starter
pm123's Avatar
My is against the back wall of the room, the TV at the opposite wall.
in theory, i could have 'rear' speakers that were to the sides of the sofa. Would that work? It is my current set up, and it's not terrible.
Would a sound bar be a better solution for me if I want a 5.1 (or 7.1) experience
I also listen to music. I will get a receiver. Can I use a receiver with the sound bar? If so, what sound bar would be compatible with that set up? (I think there is a passive / non passive issue)
pm123 is offline
post #2 of 3 Old 01-03-2011, 07:11 PM
tbraden32's Avatar
What is your budget? Rear speakers are suppose to be 90-110 degrees from listening position, so a regular system is still an option.
tbraden32 is offline
post #3 of 3 Old 01-04-2011, 11:31 AM
drfreeman60's Avatar
Liked: 52
A soundbar will not give you a 5.1 or 7.1 experience. If this is very important, you should consider seperates. A soundbar can give a simulated 5.1 experience that can be quite convincing, plus it is much easier to set up and configure. A soundbar can also improve your television sound in most cases.
For true 5.1 or 7.1, speakers may be placed on the side walls or the ceiling to the outside of your listening position and still receive most if not all of the surround experience.
David Freeman
drfreeman60 is offline
Reply Soundbars
