Fix for Vizio sound bar being unresponsive to remote - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By w0kie
  • 1 Post By dvroon
post #1 of 28 Old 12-23-2010, 09:42 AM - Thread Starter
w0kie's Avatar
If your Vizio sound bar is unresponsive to your Vizio sound bar remote just unplug the soundbar, count to ten and replug. This procedure solved my Vizio remote communication outage.
CGARNES likes this.
w0kie is offline
post #2 of 28 Old 10-30-2014, 12:07 AM
dvroon's Avatar
Liked: 1
Thank you thank you thank you. You saved me a trip to Costco to return it!
CGARNES likes this.
dvroon is offline
post #3 of 28 Old 01-04-2015, 08:36 AM
Liked: 0
Thank you so much! You rock
ryguy0320 is offline
post #4 of 28 Old 01-04-2015, 09:33 AM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Karyk is offline
post #5 of 28 Old 01-05-2015, 08:11 AM
Liked: 0
Did you leave the batteries in the remote when you did this? Stupid question, I know. I bought the 54" SW5451-C2 about a month ago, and I joined this forum pretty much just to help figure out this very issue.
I've already talked to Vizio a half dozen times, and they'd given me different variations on the following:
1) Unplug Soundbar
2) Hold soundbar power button for at least 30 seconds.
3) Remove batteries from remote
4) Hold remote power button for 30 seconds
5) Plug in soundbar
6) Put fresh batteries in the remote
7) Turn on soundbar using remote.
I've tried that so many different ways without success. I tried it with the subwoofer off, and with it on. I tried pressing every button for 30 seconds while unplugged/batteries removed. I tried leaving the batteries removed and bar unplugged for an hour.
Heck, I even both a 12 pack of AAAs just to rule out batteries.
The best I could ever manage was being able to turn the sound bar on ONCE and ONLY once after leaving it for an hour.. It was unresponsive after that.
So they sent me a new remote.
Same thing. I let them both sit for an hour, and best I could manage was being able to turn it on ONCE with unresponsiveness following that.
I also confirmed that both remotes were sending out a signal (looked at them through the facetime camera on my iPhone.)
But I don't think I tried leaving the batteries actually in the remote when removing power from the bar...
I'll need to try that once I get home from work. I'm really hoping its just some weird quirk I need to work through, and not a problem with the IR receiver, because I really don't want to have to deal with sending it back to Vizio for a replacement. I'm almost wishing I had filed for an exchange on Amazon back when I was still within the window.
Its a shame because the soundbar is awesome for what it is.
ajsmcs is offline
post #6 of 28 Old 01-31-2015, 07:25 PM
spanther's Avatar
This! Great solution thank you! Worked like a charm
spanther is offline
post #7 of 28 Old 02-20-2015, 11:00 AM
RhysOrd's Avatar
This workaround will allow the remote to work for the time being but will not permanently resolve the problem. It will most likely occur again. Working with Vizio now on mine.
Rhys
RhysOrd is offline
post #8 of 28 Old 02-24-2015, 09:40 PM
naustin's Avatar
Quoted: 333 Post(s)
Liked: 137
Originally Posted by ajsmcs View Post
Did you leave the batteries in the remote when you did this? Stupid question, I know. I bought the 54" SW5451-C2 about a month ago, and I joined this forum pretty much just to help figure out this very issue.....
Is your Soundbar trying to BlueTooth synch? The LEDs blink across the bar when you power it On. I accidentally invoked BT pairing and that killed the SB and the Remote. The only way to stop/fix the problem was to "BT pair with a device". Once paired, the SB was happy and everything was back to normal. Just an idea.
naustin is offline
post #9 of 28 Old 03-01-2015, 04:28 AM
djsketchie's Avatar
Quoted: 52 Post(s)
Liked: 31
There's a firmware fix for this now. I'm going to try and update my S3821w-C0 today and see what happens.
https://support.vizio.com/product/s3821w-c0
djsketchie is offline
post #10 of 28 Old 03-02-2015, 01:49 PM
Liked: 0
Vizio SoundBar
Thankyou This Solution Worked For me As Well
6echo is offline
post #11 of 28 Old 06-15-2015, 01:47 PM
Liked: 0
Hi to all.
I have tried everything posted here. Even updated the firmware. Nothing works on my S3020w-C0. I chatted with someone on Vizio who guided me trough several troubleshooting steps and the soundbar would not respond to the remote. He just gave up and told me he had no other solution. I have a Logitech Harmony set up for all my stuff and it doesn't respond to it either. I am quite sure the problem is not the remote(s) but the soundbar itself. I turn it on manually but every time I have to adjust the volume I have to get up and walk to it, and there is no way to set the bass or the other levels. Mine is still under warranty but I live overseas and the costs of sending it back are higher than the soundbar's itself. This is very frustrating!
Bracuta is offline
post #12 of 28 Old 08-06-2015, 01:41 PM
Liked: 0
Typically unplugging my sound bar and plugging it back in will work to reconnect my remote with the sound bar. Just recently it did not and I thought that the remote needed new batteries. Changed them and nothing. So I contacted Vizio and while the answer was a little crazy it worked like a charm and I thought I would pass it along to save you a call.
1) Remove batteries from the remote.
2) Press each button on the remote individually while the batteries are removed.
3) Replace the batteries with new batteries.
4) Unplug the sound bar from the electrical outlet and hold the power button on the sound bar while it is unplugged.
5) Once all of the steps have been completed plug the sound bar back in and turn it on from your remote.
val58 is offline
post #13 of 28 Old 08-27-2015, 07:26 PM
Liked: 0
Vizio Soundbar Unresponsive Fix-
This happened to my husband & I. I looked up the original Instructions on how to set it up and found that the "Input" button needs to be held for three (3) seconds to find an audio input channel. (input 1/Input2) so that may cause the remote to not work if you accidentally push Input and then start pushing other buttons on clicker. I shut off Soundbar and restarted it. Hope this helps.
Bobbysgirl is offline
post #14 of 28 Old 11-28-2015, 12:35 PM
Liked: 0
Thank you so much! This was an immediate fix (after I spent too long using the manual that got me nowhere). I should have thought of this myself, but your post made my day! I tested I don't know how many batteries.
CGARNES is offline
post #15 of 28 Old 11-28-2015, 12:40 PM
Liked: 0
Red face Thank you! This was an instant fix!
CGARNES is offline
post #16 of 28 Old 12-22-2015, 02:49 PM
garnetbobcat's Avatar
Firmware update working so far
Thanks to djsketchie for pointing out the firmware update! That did the trick, or has so far. Hopefully it keeps working!
Unplugging my dad's s3821w-CO for 10 seconds and plugging in back in worked, but it only allowed us to turn the unit on then off once, before requiring another unplugging.
garnetbobcat is offline
post #17 of 28 Old 12-23-2015, 02:21 PM
jjinatx's Avatar
I have a slightly different problem. My SB3821 will not turn on with my Vizio XVT473SV remote, even though the soundbar manual says it will and is the factory default. I also checked the soundbar and reset the optional setting for that feature, but still no joy. The sound bar does come on if I use the cable box remote to turn on the TV - both TV and soundbar come on.
My TV remote is bluetooth and the cable box remote is IR, so obviously the soundbar sees the IR signal, but is not getting the command over bluetooth. Maybe I need to pair the remote to the soundbar? I don't see any instructions for doing that in the soundbar manual.
One more observation is that the TV remote DOES control the soundbar volume.
jjinatx is offline
post #18 of 28 Old 01-31-2016, 12:45 PM
Liked: 0
There is a different firmware update page now. No Page Found on your link.
YachtLaw is offline
post #19 of 28 Old 01-31-2016, 02:27 PM
naustin's Avatar
Quoted: 333 Post(s)
Liked: 137
If you keep the SB on in eco mode it should. My XVT bluetooth remote works, but I have to change the volume level to "wake up" the SB.
naustin is offline
post #20 of 28 Old 05-14-2016, 08:33 AM
Liked: 0
1) Unplug Soundbar
5) Plug in soundbar
Did you find a solution to your problem? I have the same issue in my SB3821. It will not respond to the remote even after I tried all the options suggested in this thread to no avail. I know the remote is sending IR signals because I checked using the camera in my cell phone. Thanks.
Zenzicnole is offline
post #21 of 28 Old 05-14-2016, 11:40 AM
Liked: 0
post #22 of 28 Old 12-07-2016, 08:45 PM
MiamiBourne's Avatar
1) Unplug Soundbar
5) Plug in soundbar
I know this post is old but I just had this issue. I control my Vizio s3851w-d4 with my Harmony and all of the sudden the sound bar wouldn't power on. I grabbed the Vizio remote and that didn't power on the sound bar either. I'm able to get up and manually power the soundbar on and change the volume but the IR seems to not be working. I don't see a firmware update for this model and I've tried everything from holding the power button for 30 seconds while the power cable is disconnected to holding all the buttons, to taking the batteries out the remote and holding the power button...great soundbar, but now this.
Anyone else?
MiamiBourne is online now
post #23 of 28 Old 12-07-2016, 11:40 PM
brenden's Avatar
Anyone else?
Does Bluetooth still work?
Have you tried:
Enable/disable the use of a VIZIO TV remote control to power on and adjust the volume of the sound bar. To enable/disable this function, Press and Hold the Power ( ) and Volume Up ( + )buttons for 5 seconds.
Or
Reset the Sound Bar to the factory default settings.To perform a Factory Reset, Press and Hold the Bluetooth( ) and Volume Down (—) buttons for 5 seconds.
Note: This will erase all settings and preferences that you have set.
brenden is online now
post #24 of 28 Old 12-08-2016, 07:03 AM
Have you tried:
Or
The last thing I did was just leave the soundbar unplugged overnight. I'm pleased to say that it's now working with the Vizio and my Harmony remote. If I continue to have issues I'll try some of your suggestions and report back. Thanks for responding!
post #25 of 28 Old 01-04-2017, 06:54 PM
Liked: 0
Anyone else?
I'm having the same issue. Pretty regularly, I can't turn on the Sound Bar manually or with the remote. Unplugging and plugging it back in brings it back, but I'm curious to know if there is an actual fix.
littdh6 is offline
post #26 of 28 Old 01-04-2017, 07:07 PM
All the things I tried that I read about didn't work. But...recently it started working like normal. I know that doesn't help you but before you replace it or throw it out maybe you should wait.
post #27 of 28 Old 01-17-2017, 07:12 AM
Well it's back to not working again. Costco has a sale on the newer model SB4051-D5 for $280 ($100 off), but the reviews are very iffy. I really don't trust Vizio now but for the money and getting 2 satellite speakers Vizio is still the best option.
Best Buy has the older S4251w-B4 for $200 and I can add 4 year protection for $35. Also I believe I get Visa Checkout with $25 off so...old soundbar for $210 w/4 year warranty or newer one for $280 with 2 year warranty...
Also...what to do with my current soundbar as it works...just not with the remote. Oh well..
post #28 of 28 Old 01-19-2017, 07:15 AM
Well I bit the bullet and bought a new Vizio SB4051-D5 as they have a $100 off at Costco. I'll be setting it up this weekend. The reviews are up and down about this so I'm not too optimistic...hopefully all goes well.
I'm still not sure what to do with my current Vizio Soundbar. I mean it still works...just not with a remote.
Reply Soundbars
