tryn too hook up my vizio soundbar to my toshiba 37" tv HELP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-20-2011, 01:18 AM - Thread Starter
imxovrx9000's Avatar
Can't get n e sound out of the bar its saposed to be really simple I can't figure out what I'm doing wrong please message me or leave sum help THANK YOU
imxovrx9000 is offline
post #2 of 6 Old 02-21-2011, 02:26 PM
drfreeman60's Avatar
Liked: 52
What audio outputs does your TV have?
Analog? Digital?
Which Vizio soundbar?
Should be very simple for digital - optical out from TV to optical in on soundbar.
Same for analog - RCA out on TV to RCA in on soundbar.
Make sure if using analog (RCA) that you have connected to an output on the TV, not an input. The only reason I say this is this same problem was encountered by another user a few weeks ago. Input to input will never work.
David Freeman
drfreeman60 is offline
post #3 of 6 Old 02-21-2011, 02:59 PM - Thread Starter
Analog? Digital?
post #4 of 6 Old 10-07-2012, 09:15 AM
DIAMONDS38's Avatar
I have a 55 in toshiba and cant hook my vizio sound bar my old sound bar had the digital out let and rca this one only has the rca and my tv has only the vidio audio outlets what should I do????
DIAMONDS38 is offline
post #5 of 6 Old 10-07-2012, 09:20 AM
DIAMONDS38's Avatar
This sound bar does not have the optical my old one did and it quit working for my HD channels tried to switch out the cords nothing hooked it up to my other tv using RCA cables it worked fine I was thinking it was the optical ports so I bought the newest version and it doesn't have the optical only the RCA my tv has video audio and IR outlets?
post #6 of 6 Old 10-07-2012, 09:31 AM
Possumgirl's Avatar
Liked: 58
Please provide more information. What make & model soundbar do you have? What is the model of your Toshiba TV?
Possumgirl is offline
Reply Soundbars
