Sony HT-CT550W?? - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 558 Old 11-20-2013, 03:50 PM
drfreeman60's Avatar
Liked: 52
They should work. Why are you looking at a soundbar from three years ago? Sony has some new models at a lower cost that certainly are superior soundwise to the 550.
carageuw likes this.
David Freeman
drfreeman60 is offline
post #542 of 558 Old 11-20-2013, 05:05 PM
carageuw's Avatar
Quoted: 72 Post(s)
Liked: 27
Agreed, Yamaha also have some great options now albeit at slightly more expensive prices.
carageuw is offline
post #543 of 558 Old 11-20-2013, 06:01 PM
hbelok's Avatar
So what do you suggest that is cheaper with better sound and the same amount of HDMI connectivity?
hbelok is offline
post #544 of 558 Old 11-21-2013, 03:23 PM
Liked: 52
If HDMI connectivity is important, not sure. Most of the newer, reasonably priced soundbars are taking the approach of a single connection for audio from the TV to the soundbar and all components, such as DVD or Blu-Ray, connected to the TV.
Almost all of the recommended soundbars from the major publications have very limited connectivity. Most do now have blue-tooth as an added benefit.
David Freeman
post #545 of 558 Old 11-21-2013, 06:20 PM
carageuw's Avatar
Quoted: 72 Post(s)
Liked: 27
But if you rely on the ARC route, then you lose the advantage of Dolby TrueHD/DTS MA, assuming the soundbar and the BDPlayer, console (etc) supports those formats.
carageuw is offline
post #546 of 558 Old 11-21-2013, 06:28 PM
hbelok's Avatar
So would connecting components directly to the TV via HDMI, then using an optical cable to a soundbar from the TV be a better option, and one that would be able to transmit the DTS-MA or TrueHD formats?
hbelok is offline
post #547 of 558 Old 11-21-2013, 06:30 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
HDMI is the only option for lossless audio.
LexInVA is offline
post #548 of 558 Old 11-21-2013, 06:39 PM
hbelok's Avatar
So if you connect components to the 550w via HDMI, then connect the 550w to the TV via HDMI ARC, you will lose the TrueHD and DTS MA decoding feature of the 550w?
hbelok is offline
post #549 of 558 Old 11-21-2013, 08:28 PM
carageuw's Avatar
Quoted: 72 Post(s)
Liked: 27
You lose advanced decoding when you connect the component directly to the TV then connect the TV via HDMI with ARC to the 550W.
carageuw is offline
post #550 of 558 Old 11-21-2013, 09:48 PM
hbelok's Avatar
So if all the components are connected to the Sony 550W does that need to be connected to the ARC HDMI port in the TV for all the decoding to work or can the 550W be connected to any HDMI port in the TV?
hbelok is offline
post #551 of 558 Old 11-22-2013, 07:39 AM
hbelok's Avatar
So Consumer Reports gave this rating to the Sony 550W: "Sound quality: Sony's HT-CT550W had fair overall sound quality. Boomy bass has good impact but lacks definition and upper bass is recessed. Midrange is muffled, soft, echoey, and has a telephone-like quality. Very rolled off treble. Somewhat closed in, lacking airiness and room ambience except in the midrange, and fine detail and texture are missing. The system can provide satisfying volume in a medium-sized room."
Does anybody else share their sentiment or are they just full of it?
hbelok is offline
post #552 of 558 Old 11-22-2013, 07:52 AM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 49
You can read my comments on this sound bar and other sound bars here.
http://www.avsforum.com/t/1498837/soundbar-advice#post_23948166
ttlnb is offline
post #553 of 558 Old 11-29-2013, 07:33 AM
carageuw's Avatar
Quoted: 72 Post(s)
Liked: 27
I saw the 660 on sale last night at a Sony Outlet...
I assume that would be the replacement for 550.
carageuw is offline
post #554 of 558 Old 11-29-2013, 11:21 AM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 49
I've tried them both and my comments are already in the link.
ttlnb is offline
post #555 of 558 Old 11-30-2013, 07:10 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
Reviews seem to be all over the place for this particular soundbar and the same goes for the 660, which I got a few days ago. I haven't unboxed it and I'm thinking about holding on to it until the last minute as the CES show will reveal any potential replacements that could be far better spec-wise as Sony seems to bounce up and down with the specs of new products compared to old ones.
LexInVA is offline
post #556 of 558 Old 11-30-2013, 08:08 AM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 49
Reviews are all over the place because reviewers' experiences are all over the place. On a consumer site you will get a lot of positive reviews because they often have very little experience with other gear. If one is comparing this sound bar to their TV speakers they will be happy but if they compare it with other audio gear in a good environment (i.e. not on Best Buys showroom floor) you quickly realize it is at the low end of the audio quality spectrum. Professional reviewers try to be politically correct and tell you all the good points about a product. You often have to read between the lines to get their overall impression especially with sound quality.
The good news is you don't have to be a golden ear audiophile to hear the differences, you just need to be in a half way decent room without a lot of ambient noise. The bad news is there are not a lot of places to demo gear any longer. You often have to buy them and then return the ones you don't like.
I share some of consumer reports opinion and while I have a subscription I don't always agree with them. In fact CR is updating their antiquated procedures on how they measure AV gear and have hired some industry experts to help them with this. I'm not sure if their new knowledge has made it into their reviews yet.
Anyway as far as the 550 is concerned it could not reach 70db from about 11 feet away on my SPL meter in the room I was measuring. So I don't agree that it will fill a medium sized room but I don't know how they measure to make that comment. They had the same comment about the Atlantic Technology bar and that beats the Sony without a sub and totally destroys it with one, although a lot more expensive. I agree with the sound quality remarks of CR for this bar and I won't be politically correct and say this was probably the worst I have heard on anything that I have tested. I really like a lot of Sony products but none of their bars impressed me (I haven't heard their new ST7) and the 550 was the absolute worst. Highly NOT recommended IMHO. No offense to anyone here that likes it.
ttlnb is offline
post #557 of 558 Old 05-31-2015, 12:28 PM
jamieazure's Avatar
Liked: 0
Question
PC HDMI OUT -> Sat/cab HDMI IN (on 550) -> HDMI TV OUT to Benq Projector (HDMI IN) and nothing shows up. If I disconnect the tv out hdmi cable, then I hear the PC audio through the system. As soon as I plug the Projector back into the TV OUT HDMI port the audio ends, and nothing shows on the projector screen. I can take the projector hdmi cable and connect it directly to the PC and then I get the PC screen to show fine on the projector and then audio comes out the little speakers on the projector. What's the issue? Oddly, and I'm not sure consistantly it seems if i have a movie playing on the PC and while it's playing (via the direct projector cable) switch the cables around so that it goes from teh PC -> 550 -> Projector everything will work... occasionally.... it's all very confusing....
Any ideas?
jamieazure is offline
post #558 of 558 Old 09-14-2016, 03:15 PM
jtrippe's Avatar
I've had this soundbar sitting in an extra room for a while and decided to move it to my main TV. I've read through all of the threads and adjusted the sound accordingly. It sounds pretty good in my living room. What I can't figure out is how to see the volume on my TV. I have an LG50PK550 plasma TV. My Apple TV 4, Tivo Bolt and Sony Blu-Ray all connect to the soundbar via HDMI and then to the HDMI 2 on the TV. I use HDMI 2 because that input was professionally calibrated. To see the volume on TV do I also need to add an optical cable from TV to soundbar? If so, would it affect the sound quality at all? Thanks in advance for the help.
jtrippe is offline
Reply Soundbars
