Sony HT-CT550W?? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 558 Old 10-03-2011, 09:08 AM
LBJ2's Avatar
Originally Posted by daz655321 View Post
I did pick up a couple more high speed hdmi cables along with the soundbar. I liked the amazon option better than ebay because of the 1 day shipping option with amazon prime. I am sure the customer service will be better in case I need to return it or have issues. Hope the set up goes smoothly with my revue as well.
Sounds like you are all set. BTW, I didn't have any problems as a first time Revue user quickly connecting the Revue through the STB and 550W. Since you are already familiar with the Revue, should be a snap for you too. (Now if they would just release the 3.1 Honeycomb update...)
LB
LBJ2 is offline
post #152 of 558 Old 10-03-2011, 10:28 AM
daz655321's Avatar
The only problem I have with the Revue is that I seem to never use it. I tend to use my xbox 360 for netflix and my desktop or laptop for web browsing. I kinda jumped the gun because I was excited at the price drop. I seem to buy things on impulse and never use them a lot. Hope the Honeycomb update improves the browser speed.
daz655321 is offline
post #153 of 558 Old 10-03-2011, 12:10 PM
LBJ2's Avatar
In line with the topic of this forum.....I'm still testing out the Revue with the HTCT550W Receiver. It certainly works with the 550W and was easy enough to connect--now I am just trying to determine if there is any affect on how the 550W processes audio formats like Dolby Digital coming from my DirecTV DVR/Receiver through the Revue to the 550W.
Apologies in advance to my fellow 550W avsforum contributors for going off topic for a brief comment or two....the Revue certainly provides a robust web browser for TV web browsing. I am posting this msg via the Revue web browser on my big screen TV. The web browser that comes with my TV is so painfully slow it's essentially worthless--so the Revue is a major value -add in this area for me. There are many other positives to this device too--I can't wait for the 3.1 Honeycomb update to come out. Thanks for the recommendation
Back on topic of this forum...and a question to you or any others that have connected the Revue to the 550W through a cable/satellite box--do you see the audio format like Dolby Digital or DTS displayed on the front panel of your 550W when viewing content from your cable or satellite service? Or do you see LPCM displayed?
Hello--Today, I was finally able to process Dolby Digital (not LPCM) from my Revue to my 550W. The Dolby Digital ( as opposed to LPCM) lit-up nicely on the Receiver display once I got this figured out while playing relevant video.audio from the Revue and of course I did hear the difference.
In order to do this you have to use an optical cable from the Revue in addition to the HDMI cable--then set your other components e.g., TV & the 550W to process audio from both the optical and HDMI cables. Also set the Optical Sound output on the Revue itself from PCM to Dolby Digital. ( Note: The Revue only processes PCM or Dolby Digital--it does not process the other surround formats DTS or DD HD etc.)
Took a little doing--but the enhanced sound quality was worth it. I used the Surround Sound tests from YouTube as my audio test source played on the Revue.
BTW, for those of you who would like to test the Surround Sound effects and Bass capabilities of your HTCT550W with multiple Surround Sound audio tests and effects e.g. DD, DTS, 5.1, 7.1 THX
--check out all the clips they have on YouTube starting with:
http://www.youtube.com/watch?v=qlwXv9VXY80
Enjoy!
LB
LBJ2 is offline
post #154 of 558 Old 10-03-2011, 12:28 PM
LBJ2's Avatar
Yes--Its a great Web Browser for my big screen which I like--but as is functionality 2.1, overlaps with my smart TV, blu-ray, and PS3 streaming capabilities--so hoping the 3.1 upgrade brings some more bells and whistles. (I think for people who don't have other streaming capabilities--the Revue is pretty good little box for $99)
LB
LBJ2 is offline
post #155 of 558 Old 10-04-2011, 03:32 PM
daz655321's Avatar
do i need to use the digital optical cord that comes with this? connecting from the receiver of the ct550w to my tv?
post #156 of 558 Old 10-04-2011, 03:39 PM
LBJ2's Avatar
Oui. That's what I used. Connected the optical and HDMI cable from my Revue to the Sat/Cable input to the 550W. If you have a STB then Revue-STB-550W
LB
LBJ2 is offline
post #157 of 558 Old 10-04-2011, 04:25 PM
daz655321's Avatar
OK just to make sure I have this right, I have this set up so far as:
XBOX360 HDMI --> CT550W
BLURAY HDMI --> CT550W
REVUE HDMI -> CT550W
Cable Box HDMI --> REVUE
CT550W HDMI -->TV
Now forgive me for being stupid but, from which two boxes am I hooking up the optical cable to? I seem to be misunderstanding what you mean.
post #158 of 558 Old 10-04-2011, 10:21 PM
pretender17's Avatar
CT550W HDMI -->TV
Hi daz... (or anyone).
Can you confirm whether you get full surround sound effect (Dolby Digital or DTS amps lit up?).. when you are playing game through XBOX 360 with 550W..
or you need to connect an optical audio cable from XBOX 360 to the 550W as well?
AFAIK XBOX 360 doesnt support bitstream...
I'm interested in purchasing but need to make sure on above..
Thanks...
pretender17 is offline
post #159 of 558 Old 10-05-2011, 04:56 AM
bigcat's Avatar
Quoted: 104 Post(s)
My guess is that most setups don't need this. I think the only scenario for this is that your setup (TV, hdmi) does not support ARC, and you use your TV as the source of the audio sometimes (like using the built-in TV tuner for something, like local channels, etc)
BenQ W1070/Silver Ticket 120"/Denon X4200W/Infinity Primus | Vizio 80" 3D LED M801D-A3 w/ Denon X3200W/Infinity Primus | Sony Bravia XBR-60LX900 w/ Sony HTCT550W 3D Sound Bar | Sony SXRD KDS-R70XBR2 w/ Onkyo HT-S770 | Sony PS3 (Slim) | DIRECTV Genie HR44-500, C41s | Harmony 700
bigcat is offline
post #160 of 558 Old 10-05-2011, 05:34 AM
LBJ2's Avatar
CT550W HDMI -->TV
Daz: I dont have a STB connected to my Revue and 550W as I use OTA (Over-the-Air) roof top antenna on this set. However, I think this will work for you:
Keep all the same HDMI connections as you have indicated above. In addition try connecting the optical cable from the Revue to the HTCT550W OPT SAT/CATV IN.
Note:
Revue --Set Sound Optical Output to Dolby Digital (not PCM)
550W --Set AUDIO INPUT Mode to OPT on the Amp menu ( not Auto). Sounds counter-intuitive I know but this will also enable HDMI audio in for everything else.
Verify: When you play audio from the Revue to your 550W in the SAT/CATV Input mode you should see the OPT light up on the Receiver as opposed to HDMI and the Dolby Digital light up as opposed to LPCM.
Then have some fun with this surround sound helicopter flying around your room. http://www.youtube.com/watch?v=qlwXv9VXY80
Let me know if this works for you.
LB
LBJ2 is offline
post #161 of 558 Old 10-05-2011, 05:45 AM
LBJ2's Avatar
Bigcat-- I agree except in the case of the Logitech Revue. Unfortunately, the Revue requires the HDMI cable for HD video and the Optical cable to output Dolby Digital Surround Sound from the Revue to the 550W. (With just the HDMI cable the Revue only outputs in PCM to the 550W)
LB
LBJ2 is offline
post #162 of 558 Old 10-05-2011, 02:48 PM
daz655321's Avatar
Thanks...
I will have to check tonight to see if the xbox plays DD or DTS. If not, I will connect the optical cable from the 360 to the 550W. I played a few games yesterday and they sounded fine but I never checked to see what sound was being used.
I am pretty new to any sort of surround sound, so what is good for me might not be all that good for those on this site who have much higher expectations when it comes to sound. I will say that sampling X-Men first class on bluray with the volume at only 13, the sound was very clear and bass was great. This probably annoyed my downstairs neighbor so going higher than 13-15 at night is definitely not going to happen.
post #163 of 558 Old 10-06-2011, 01:17 AM
Thanks man!... will wait for your feedback...
post #164 of 558 Old 10-07-2011, 04:13 PM
Fletchrrr's Avatar
Hello.
You should be able to connect the 550W to most TVs ( that support HDMI and/or Optical cable connections). The new Sony TVs provide a separate "Home Theater app" so you can view and manage a sound system menu on the TV display itself. If your TV doesn't provide such an app, no worries then you would just use the menu display on the 550W receiver itself.
My Sony TV has an optical cable output instead of HDMI and am wondering if the quality suffers much. Am trying to decide if its worth purchasing the 550W. Would it still be helpful to upgrade my HDMI cable to 1.4 from sat RX to TV? I wear hearing aids to help with the higher frequencies. Thanks for your responses.
Jim
Fletchrrr is offline
post #165 of 558 Old 10-07-2011, 05:20 PM
Possumgirl's Avatar
Liked: 58
Jim
If you get the 550W, you'd connect your sat box to the 550W via HDMI, and then connect the 550W to your TV via HDMI. You wouldn't need to use optical unless you have things connected to your TV instead of to the 550W.
Possumgirl is offline
post #166 of 558 Old 10-07-2011, 05:57 PM
Fletchrrr's Avatar
Thanks for settling my confusion.
post #167 of 558 Old 10-07-2011, 11:58 PM
snipa's Avatar
Does the onscreen menu only work on Sony ProductS? And only through HDMI?
snipa is offline
post #168 of 558 Old 10-08-2011, 05:05 AM
LBJ2's Avatar
Hello: The Home Theater App ( which allows for the on-screen amp menu) is only available on the Sony 2011 Smart TVs. For all other TVs you would use the 550W Receiver display.
LB
LBJ2 is offline
post #169 of 558 Old 10-09-2011, 07:51 AM
daz655321's Avatar
Played a few games on my 360 and watched some videos that were on a flash drive. When I played the games (gears 3 and Dark Souls) the receiver showed DD and not lpcm like it showed when watching video files.
post #170 of 558 Old 10-10-2011, 08:22 AM
avnewbe's Avatar
Hello: Yes IMO you have to spend a little more time adjusting this system and using the right cables then the previous Sony Sound Bars.
Couple of things to check:
  • Use only marked "High Speed" HDMI cables ( that means 1.3 a, b, c or 1.4) for all your connections.
  • Try turning off Aduio DRC.
  • Try turning on/off your night mode.
  • Do adjust the Bass, Treble tone levels ( separate from the SW or CNT settings).
  • Make sure your TV speakers are turned off completely and your TV is set to output sound to the Audio System ( 550W)
  • Do output audio from Bluray/PS3 in Bitstream not PCM( You can check this on the receiver display--you should see DTS/Dolby displayed not LPCM ). I noticed a significant difference in clarity and detail when sending DTS HD via Bitstream from my bluray player to the 550W.
  • Change the position of the sound bar--sometimes the cabinet itself can cause distortion e.g., surround wood, glass, metal etc.
  • Change the position of the S/W
  • Test this system with a Bluray disk DTS or Dolby. (Some broadcast programming from radio, OTA, cable or satellite just sound terrible no matter what.)
The above seem to make the biggest difference from those I have chatted with on the various forums as well as the product comments on Amazon.com. Hopefully some of these will help you too. Let me know.
Hi again LBJ2,
I've followed most of your suggestions and they do help.
I had my audiophile friend come over for his input, the first issue he brought up was the lack of left/right speaker controls. Maybe because of this, or just because it's a soundbar with L/R speakers so close together, there isn't much of a stereo effect.
He was sufficiently impressed with the audio from Underworld and the Matrix (DVD, not BR) lobby and helicopter scenes, but slightly put off by the audio in the DVD menu until we switched soundfield from Movie (where menu audio loop was terribly hollow-sounding) to stereo or standard. Obviously one normally wouldn't stay too long in the menu system, but he noted his own system automatically switches sound fields if the channels aren't available.
He also confirmed what others said about soundbars in general: they sound much better higher up. It normally site slightly elevated off my TV table (0.5m above floor), but when I held it up against the wall above the TV about 1.3m (4'4") high, he said it made a huge difference.
A non-audio issue: I have the S/W under a small table by the couch, but there is faint ozone or other chemical smell whenever it's on, and especially noticeable during/after heavy bass. If I'm watching TV more than an hour, I start to get a headache. I thought it would disappear after using it awhile, like new car smell, but it hasn't happened yet. I had put the S/W there because it didn't add clutter to the room, and it was nice to have the bass effect next to me, but is there a better/proper place to put the S/W?
And for that matter, is there an "sweet spot" distance between the soundbar and your ears?
avnewbe is offline
post #171 of 558 Old 10-12-2011, 07:28 PM
LBJ2's Avatar
Originally Posted by avnewbe View Post
Hi again LBJ2,
Good to hear some of my suggestions helped. Thanks for letting me know that. I am going to try your suggestion as well and try placing my sound bar up higher to see if I notice a difference. (Sweet spot for my ears so far for the best surround sound effect is about 8' away as close to the center position of the sound bar as I can.)
Too bad about that odd chemical smell you are getting from the SW--that doesn't sound good. IMO something else might be going on there that may need to be checked out like the SW power supply or wiring ( just to be safe).
LB
LBJ2 is offline
post #172 of 558 Old 10-12-2011, 07:44 PM
Sonyboy's Avatar
Quoted: 77 Post(s)
Liked: 82
Has anyone had any hands on with the yamaha yht-s400 compared to this sony model? I'm looking at the both models and having a hard time making a decision. They are priced about the same ballpark.
Sonyboy is offline
post #173 of 558 Old 10-16-2011, 07:23 AM
macbookq's Avatar
We finally picked up the system this weekend - here is our current setup:
FIOS Motorola Cable Box / Sony BDP-S580 connected with HDMI
HDMI Connection to KDLXBR5
We are ordering in wall high-speed HDMI connections this week through Monoprice.
So far we are enjoying the sound (music) streamed through the DVD player and are working on figuring out the optimal settings for movies/tv usage.
Basic but silly question - How can we watch TV using the TV speakers vs. the surround sound once connected?
macbookq is offline
post #174 of 558 Old 10-16-2011, 09:39 AM
Possumgirl's Avatar
Liked: 58
See your manual under AMP settings for Pass-through. With that enabled, you just turn off the soundbar and audio is sent back to the TV speakers (assuming you don't have the TV speakers turned off).
post #175 of 558 Old 10-16-2011, 03:23 PM
macbookq's Avatar
So strange... took your suggestion and still nothing from the TV....
macbookq is offline
post #176 of 558 Old 10-19-2011, 09:30 PM
Yardl3y's Avatar
Just ordered a CT-550W today, coming in on Friday! Anyone else have any settings they'd like to share?
Yardl3y is offline
post #177 of 558 Old 10-24-2011, 03:48 AM
LBJ2's Avatar
Sony HT-CT550
"Ratings + Specs
Design
7
Performance 8
Value 8
Overall 7.7"
http://www.soundandvisionmag.com/pho...ge=5#container
"BOTTOM LINE Although I had some issues with Sony’s system, there is still a lot to like here. The sound quality was not my cup of tea, but if you prefer more aggressive tuning, this system will impress you. It plays loud and its subwoofer is solid. My only other quibble is fairly minor: It’s nice to have a FM radio in the soundbar, but I would have traded that for a USB port. At its relatively modest price point, though, this is a very good system."
LB
LBJ2 is offline
post #178 of 558 Old 10-27-2011, 06:56 PM
avnewbe's Avatar
Did you have a chance to try placing the soundbar higher? How did you find it?
I thought about mounting it directly on the wall but the back wall has a vent duct that juts out 20cm, that might deflect the sound from the right channel, so I might add a wall shelf and just put the soundbar on the leading edge of that instead.
I couldn't stand the smell anymore and moved it out into the open, beside the TV table. It actually sounds/feels a lot better, and I notice no smell now.
avnewbe is offline
post #179 of 558 Old 10-30-2011, 08:45 PM
LReyes66's Avatar
Quoted: 57 Post(s)
Hello, i made the mistake of getting a nice soundbar w/o hdmi repeaters (polk audio 6000 surroundbar if anyone is interested )...
and well i just wanna see the dif between the ct150 and 550.
Well my current set up has my wireless sub under my tv, so really i dont need the wiresless sub.
So with not caring about a wireless sub, how well do the 2 perform? any difference? I see the 150 is 3.1 as the 550 is 2.1, any dif?
LReyes66 is offline
post #180 of 558 Old 10-31-2011, 05:19 AM
LBJ2's Avatar
Hello--yes I had another person hold the soundbar above my TV but didn't notice any significant improvement in quality as opposed to placing the soundbar at the base of the TV. (Not sure this was a good test-- My TV is using the tabletop stand so I don't really have a way to relocate the soundbar above the TV--but thought I would give it a listen placing the soundbar higher up.)
LB
LBJ2 is offline
Reply Soundbars
