Sony Ht-CT550w owner settings - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2011, 10:52 AM - Thread Starter
rechapotamus's Avatar
What settings are owners using to get the best sound out of this device?
rechapotamus is offline
Old 10-19-2011, 10:26 PM
Yardl3y's Avatar
Would like to know the same. Anyone?
Yardl3y is offline
Old 01-06-2012, 05:15 AM
klm938's Avatar
i think this is de best setting:
Here are the setting I used to get started:
Sound Field: Movie
Amp Menu (Amp Menu Button and then use the up/down and left/right arrows to navigate) ....Level .......CNT Level: +4 ...... SW Level: +6 ...... Audio DRC: Auto
.....Tone ......Bass : +5 ......Treble: +3
.....Audio .....A/V Synch: On (there was a slight delay between the picture and sound that was noticeable when this feature was turned OFF. Turning it on corrected the problem) ......Dual Mono: Main ......Night Mode: Off. (Turning the function ON enables clear voice and lowers Bass at low volumes) ......Input Mode: Auto
have a try
klm938 is offline
Old 08-08-2014, 08:31 PM
jcrawford21's Avatar
Sound Field: Movie
have a try
Thank you ! Lost all my settings on a cold reset of the unit. Good vibes your way sir !
jcrawford21 is offline
Sony Ht Ct550w 3d Sound Bar Home Theater System With Wireless Subwoofer Accessory Kit
