Klipsch Gallery SoundBar G-42 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-13-2011, 10:07 AM - Thread Starter
Elihawk's Avatar
Quoted: 1339 Post(s)
Liked: 1169
Amyone heard this soundbar and/or have a review? Passive, with 4 3.5 inch woofers and 3 horn tweeters...
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #2 of 11 Old 12-02-2011, 11:32 AM
ejh2854's Avatar
Quoted: 26 Post(s)
Liked: 35
I've just finished mounting one to the wall; will share impressions once it's under power and integrated (also installing a Denon AVR-4311).
Did test-drive it a little in two-channel mode, with and without s/w for reinforcement... gut feel is that it's definitely going to require plenty of low-end support, but a very clear and open sound otherwise.
Went to the soundbar strictly for wife-appeasement, but since it was her idea it comes outta her side of the budget
There is no Honor in Mediocrity
ejh2854 is offline
post #3 of 11 Old 12-05-2011, 08:25 PM
ejh2854's Avatar
Quoted: 26 Post(s)
Liked: 35
Ran the Audyssey setup this evening, then paged through a short list of CDs and movies. Feeling slightly "meh" about the G-42 for music reproduction so far although it does yield pinpoint, articulate dialog for movies.
I suspect my listening room is a bit too big for it- but in all fairness am only just beginning to scratch the 4311's capabilities at this point, so the key to sonic nirvana may be just around the corner.
ejh2854 is offline
post #4 of 11 Old 12-06-2011, 06:57 AM
flickhtguru's Avatar
Liked: 111
Just curious why you went with the 4311. That's a 9.1 receiver, and wow that's a lot of receiver for that sound bar and very expensive too.
Shawn
flickhtguru is offline
post #5 of 11 Old 12-12-2011, 08:38 AM
MusicFirst's Avatar
Yeah, that is a lot of receiver for a soundbar.....
MusicFirst is offline
post #6 of 11 Old 12-28-2011, 08:26 AM
ejh2854's Avatar
Quoted: 26 Post(s)
Liked: 35
The two decisions weren't really related to each other.
Regarding the 4311, I'd decided it was time to step up from an older Sony ES-series AV receiver and wanted to future-proof as much as possible- we'll likely be moving within the next year or so, and a dedicated HT room has already been established as an absolute requirement in the new place
In the current house, the soundbar yields a high SAF as it integrates well with her new den furniture The old setup was Polk LSi7s as FR/FL with a CSi6 center, and the finishes and sizes just didn't cut it appearance-wise any more.
I'll hang onto the Polks for now (still using a pair of FX300i as SR/SL) and add something in the way of a matching tower as FR/FL (or build DIY) once we get settled in the new home... the LSi7s should work well as front-wides, and I can add more rear reinforcement when the time comes. The soundbar will be recycled for bedroom or kitchen zone 2/3 usage, since she likes the styling and isn't fussy about how it sounds.
FWIW the G-42 definitely has more to offer than originally thought, now that I've dinked around a little more with the 4311... it still won't take your breath away, of course but for movie dialog at normal listening levels it's working well.
ejh2854 is offline
post #7 of 11 Old 01-23-2012, 05:59 AM
styxx_78's Avatar
So, as for the Klipsch G-42...if you were to buy a buy a soundbar again...would that be the one?
styxx_78 is offline
post #8 of 11 Old 01-26-2012, 03:29 PM
rramacha's Avatar
Quoted: 121 Post(s)
Liked: 34
I have mine delivered today and will be using Onkyo Tx 609 to drive this. I also did for the very same WAF. I am converting my garage in to media room with epson 9700 projector Av8003 Preamp Sherbourn 7 channel 2100 W amp. I am using this set up with Klipsch RF-7 II Speakers with this set up.
rramacha is offline
post #9 of 11 Old 03-08-2013, 08:17 AM
SFabozzi's Avatar
I have this speaker, hooked up with a Yamaha RX-V473 receiver, and Klipsch SW-308. For my Great room, the sound is superb!
Panasonic TC-P60VT60 TV
Pioneer BDP-430 3D Blu-ray Disc Player
Yamaha RX-V473 Receiver
Klipsch G-42 Soundbar
Klipsch SW-308 Sub
Harmony One Remote
SFabozzi is offline
post #10 of 11 Old 04-11-2013, 06:57 AM
jrc22ski's Avatar
FWIW the G-42 definitely has more to offer than originally thought, now that I've dinked around a little more with the 4311... it still won't take your breath away, of course but for movie dialog at normal listening levels it's working well.[/quote]
I am also considering the G-42 to complement a system with built-in Atlantic Tech ICTS 6.3 Tri Mode rear speakers (in ceiling) and Atlantic Tech IC-NC-6 sub (in wall).
Any thoughts on how the G-42 will sound complement by the above set-up?
I have not decided on a receiver yet...
jrc22ski is offline
post #11 of 11 Old 04-10-2014, 02:23 PM
tludlam's Avatar
Total audio newbie and I'm doing a family room renovation and i have tentatively settled on the following. The only piece I have now is the tv.
60" LG 60LN5600
Klipsch G-42 mounted to the bottom edge of TV
Dayton 6.5" CS620W in-wall rear surrounds
Dayton Sub-800 woofer
Denon AVR-E400 7.1
The components will be housed in a cabinet 25' across the room from the tv via wires under the floor, so there will be 30+ feet of wire between the AVR and the G-42. Should I be worried about any power loss over that far a run?
Is this Denon model (185w/channel) going to be enough?
Any other pitfalls for the unwary with this planned set up?
tludlam is offline
Reply Soundbars
Klipsch Gallery G 42 Soundbar 1 , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Polk Audio Lsi7 Bookshelf Speakers Pair Ebony , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Yamaha Rx V473 Receiver , Klipsch Sw 308 Reference Series 300 Watt Subwoofer With Wireless Kit
