Best soundbar for Sony 55HX820? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-10-2011, 11:24 PM - Thread Starter
Apk07's Avatar
Just got this TV and I'm not impressed with the audio quality. I was looking for a soundbar, but its tough because of the low clearance under the HX820. I'm afraid a soundbar will cover up the IR sensor and such. I need something budget friendly, too
Apk07 is offline
post #2 of 4 Old 11-11-2011, 11:26 AM
Tuan's Avatar
Quoted: 13 Post(s)
Sony HT-CT350 includes a mounting bracket that bolts it between the TV and stand so nothing is blocked.
Tuan is offline
post #3 of 4 Old 11-11-2011, 11:50 AM
Possumgirl's Avatar
Liked: 58
True, but it's only designed for certain 40/46" models. The HX800 is listed as one of them, but whether it would work with the HX820 in a larger size, I've no idea.
Possumgirl is offline
post #4 of 4 Old 02-19-2012, 09:19 PM
jimichunga's Avatar
Nope won't work. I just picked up a 46" HX820 & the mount assembly is completely different than what the (CT350's) directions show.
I was hoping to be able to mount my CT-350 directly but now I'll just have to go back to the sound bar brackets I had been using on my Vizio.
jimichunga is offline
Reply Soundbars
Sony Bravia Kdl55hx820 55 Inch 1080p 3d Led Hdtv With Built In Wi Fi Black , Sony Ht Ct350 Virtual 5 1 Sound Bar
