Compare Sony CT152 vs Sony HTCT550 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-29-2011, 08:17 AM - Thread Starter
dogman_1's Avatar
I'm looking at purchasing a sound bar for my Sony HX820 model LED. Can someone please recommend either the CT150 or CT550 sound bars? I wanted to keep it to a Sony sound bar.
Any help is most appreciated.
dogman_1 is offline
post #2 of 3 Old 12-31-2011, 08:35 AM - Thread Starter
dogman_1's Avatar
Any help would be appreciated
dogman_1 is offline
post #3 of 3 Old 01-02-2012, 11:53 AM
cmoses's Avatar
I recently purchased the 550 and have been very pleased with it. I am currently using it with my Phillips TV which I plan to upgrade soon, possibly to a Sony. The 550 was a huge improvement over my TV speakers. It was very easy to hook up, plug everything into the 550 receiver, 1 HDMI to the TV and I also hooked up the digital output from the TV back to the 550 receiver. It automatically mutes the Phillips TV when I turn on the soundbar. I used the settings from the 550 thread, to set the bass, treble, etc. I made sure the DirecTv box and the Blu-Ray were outputing digital signals and eveything sounds great. The wireless sub is easy to use and can be put anywhere. I am very happy with the 550 and would recommend it.
I had to do my settings through the 550 receiver display. I know some models of Sony TV's will allow you to show the settings on screen so they are probably easier to set up.
cmoses is offline
Reply Soundbars
Sony Ht Ct550w 3d Sound Bar Home Theater System With Wireless Subwoofer Accessory Kit
