Will Logitech Harmony remote work with Vizio VHT215 soundbar? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-29-2011, 09:41 AM - Thread Starter
rocco1005's Avatar
I need a universal remote that will control the vizio vht215, are there any that will do this? I would like to get the logitech harmony remote. Has anyone done a universal remote with this soundbar yet?
rocco1005 is offline
post #2 of 7 Old 12-29-2011, 02:42 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
There is a Vizio universal remote sold at Walmart that should work. But the Logitech probably should work as well, but don;t know for sure.
tylerSC is online now
post #3 of 7 Old 12-29-2011, 06:59 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It should work just fine. I just got a Harmony 1000 that so far is stellar. The number of products it supports is truly astounding.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 7 Old 01-03-2012, 12:45 PM
Electricide's Avatar
I've got a 510 sound bar and the ~$35 bottom of the line harmony remote. The all-black with no screen remote. I was able to program every button of the soundbar remote. The harmony has an IR reader built in, so it can duplicate any remote's signal.
The issue is remembering which combination of buttons is the "center channel" volume, versus the "treble" control
Electricide is offline
post #5 of 7 Old 11-29-2012, 04:57 PM
Paul210's Avatar
Quoted: 23 Post(s)
Liked: 31
I've got a Harmony One and I've been pulling my hair out trying to get it programmed correctly to always operate the Vizio VHT215 correctly. The sound bar seems to have a mind of its own.
Panny Plasma Junkie: TC-P50VT20, TC-P50G15, TH-42PX60U
Paul210 is offline
post #6 of 7 Old 12-05-2012, 01:56 PM
drfreeman60's Avatar
Liked: 52
I have had two Harmony remotes (one is new and less than $ 70). Both controlled Vizio soudbars and everything else I could throw at them.
Make sure that you connect on-line using the Harmony software, not the basic on-line setup. The Harmony software allows much greater control than the on-line setup.
List the Vizio soundbar under amplifier for full control.
David Freeman
drfreeman60 is offline
post #7 of 7 Old 02-05-2013, 02:13 PM
MaratFacegit's Avatar
Thanks. Really helpful tip re Amplifier!
MaratFacegit is offline
Reply Soundbars
Vizio Vht215
