subwoofer with suboutput - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-01-2012, 08:28 AM - Thread Starter
inf1uence's Avatar
are there any sound bars with an optical input, and a subwoofer output allowing me to hook up my own powered sub? i really dont like that vizio one from walmart but i want something similarly priced to it with same features.
inf1uence is offline
post #2 of 3 Old 01-02-2012, 02:27 AM
l3ftonm3's Avatar
JVC TH-BC1
Yamaha YAS-101
l3ftonm3 is offline
post #3 of 3 Old 01-02-2012, 05:56 PM
Gened45's Avatar
My Yamaha 101 has an RCA jack dedicated to a subwoofer I believe it is a mono cable that would be conneted. Don't think that a subwoofer connects via a digital connection but I may be way off on that.
The 101 also has a jack on the back that connects to a jack on a Yamaha subwoofer called a system connector that would allow the Yamaha subwoofer to be turned off via the remote.
I just purchased a cable from radio shack that would allow me to hook up my soundbar to one of my existing subwoofers that have the push in type connectors .The wire has a RCA plug on one end and the other end is stripped forming two stranded ends so I can push them into the subwoofer connectors. Haven't done it yet though.
Gened45 is offline
Reply Soundbars
Yamaha Yas 101bl Front Surround System Piano Black
