Yamaha YAS-101 Mounting Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-05-2012, 05:45 AM - Thread Starter
beardawg's Avatar
Hello, looking for input from anyone who has the Yahama YAS-101 soundbar.
I have a toshiba led 46" and was looking at this soundbar option, wanted to mount the soundbar above my TV using these soundbar brackets - (http://soundbarbrackets.com/)
The two questions I have:
1. Can you remove the feet from the soundbar?
2. Has anyone successfully used the bracket with this soundbar?
beardawg is offline
post #2 of 4 Old 01-05-2012, 06:05 AM
Gened45's Avatar
Yes you can remove the feet. It's in the manual as to how to do it. don't know about the brackets. If you wallmount it there is a template in the box that you can use to place the screws.
Gened45 is offline
post #3 of 4 Old 01-05-2012, 07:50 AM
hifigear's Avatar
It is very easy to wall mount the Yamaha YAS-101, all of the materials and instructions on how to do this are included with the product.
hifigear is offline
post #4 of 4 Old 04-14-2013, 01:34 PM
JamesP-C's Avatar
Hi I have just bought exactly the same combination to fit to my Sony 40" TV. How did you get on?
JamesP-C is offline
Reply Soundbars
Yamaha Yas 101bl Front Surround System Piano Black
