Colby Soundbar (CSMP88) - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2012, 08:51 AM - Thread Starter
fjacky's Avatar
I was just about to buy this soundbar but was tipped off by someone to make sure I have the proper output on my TV. I just bought a new TV so in my head I thought it would have everything I'd need. The colby has RCA cabling, but it looks as though my TV only has optical audio out (see attachment)
Am I out of luck?
fjacky is offline
Old 01-07-2012, 10:39 AM
BuffaloJim's Avatar
Yes, if those are the only jacks your TV has, you're out of luck.
Jim
BuffaloJim is offline
Old 01-07-2012, 12:52 PM - Thread Starter
fjacky's Avatar
What a drag... Very affordable too.
thx
fjacky is offline
Old 01-08-2012, 09:55 AM - Thread Starter
fjacky's Avatar
It seems the lower priced soundbars only have the RCA cables and not the hookup for the digital audio output.
fjacky is offline
Old 01-08-2012, 10:02 AM
Possumgirl's Avatar
Liked: 58
Does your TV have an audio setting to output PCM from optical? If it does, you could use the Coby bar by purchasing a digital to analog converter. You could also consider the Vizio VSB200 which is about the lowest priced bar around. It has optical in, but only accepts PCM.
Possumgirl is offline
Old 01-08-2012, 10:12 AM
Elihawk's Avatar
Quoted: 1013 Post(s)
Liked: 854
I had a Colby soundbar for awhile and while they are cheap, they sound like they are cheap as well. Only a little better than the TV speakers! I ended up giving it to my nephew.
There are many powered digital to analog converters available for 40-60 bucks.
edit...I did NOT have the model you listed above!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
