Vizio 510 HD formats - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-01-2012, 11:28 PM - Thread Starter
elroy12's Avatar
Looking to possibly pick this up but wondering if it decodes Dolby True HD or DTS HD streams from blu ray disks?
elroy12 is offline
post #2 of 4 Old 02-02-2012, 10:15 AM
Possumgirl's Avatar
Liked: 58
It doesn't have HDMI input so it can't receive the lossless codecs.
Possumgirl is offline
post #3 of 4 Old 02-03-2012, 09:38 AM - Thread Starter
elroy12's Avatar
Ok. So there are sound bars out there that can receive these codecs?
elroy12 is offline
post #4 of 4 Old 02-03-2012, 10:38 AM
Possumgirl's Avatar
Liked: 58
Yes. Two that come to mind are the YSP-2200 and the Sony CT550W. You may want to review some of the very good info in the "help me choose" thread. If you just start from early January and read from there you should get ideas of which soundbars may suit your needs.
Reply Soundbars
Vizio Vht510 5 1 Channel Home Theater System Black , Yamaha Ysp 2200 Digital Sound Projector Black , Sony Ht Ct550w 3d Sound Bar Home Theater System With Wireless Subwoofer Accessory Kit
