Surge protector for SB + TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-02-2012, 11:46 AM - Thread Starter
cynation's Avatar
Hello,
I am in the dark deciding what surge protector to purchase for my SB+TV. I am looking for a lower budget model, in the sub-$70 range. Is there any specific make / model that fellow AVS folks recommend? I will mainly use it for my SB+HDTV.
cynation is offline
post #2 of 2 Old 02-02-2012, 11:55 AM
FAUguy's Avatar
Quoted: 94 Post(s)
I too need one for the HDTV, SoundBar, cable box and dvd player.
Not sure if there's a big difference between the ones that are under $20 or over $50.
FAUguy is offline
Reply Soundbars
