Vsb200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-05-2012, 03:09 PM - Thread Starter
drdean69's Avatar
I have Directv hooked up to a LG 42LV5500. I just bought the vsb200 and can't get the rca cables to produce sound. I haven't bought the optical cable yet. Could there be a compatability issue. I would think the connection would be simple. Suggestions?
drdean69 is offline
post #2 of 3 Old 02-06-2012, 11:51 AM
gehrig38's Avatar
I have the same set and the same soundbar. They do work together. There is an input button (on top of the soundbar and also on the remote). Try pressing that. There are 3 different input settings, but the soundbar will only work on one of them.
When you press the input button, you will see one of three different white LED lights illuminate on the soundbar. On mine, the soundbar works when the light that's furthest to the right is illuminated.
Hope that helps.
gehrig38 is offline
post #3 of 3 Old 02-08-2012, 11:03 AM
alec32's Avatar
yup
alec32 is offline
Reply Soundbars
Vizio Vsb200 Universal Hd Sound Bar , Lg Infinia 42lv5500 42 Inch 1080p 120 Hz Led Lcd Hdtv With Smart Tv
