Sound fades in & out on Vizio 215? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-14-2012, 07:30 PM - Thread Starter
RJGiants75's Avatar
Hey all,
I bought the Vizio 215 about a month ago. When listening to tv shows, the voice volume constantly is changing from normal to low. I had it hooked up via hdmi buy changed it to digital optical cable toslink. Same issue. Is this normal or do I have a lemon?
RJGiants75 is offline
post #2 of 8 Old 02-15-2012, 10:47 AM
GMcDougal's Avatar
I've noticed that mine does this as low volumes with truvolume on. I keep it on 5 or 6 and it stops.
GMcDougal is offline
post #3 of 8 Old 02-16-2012, 12:44 PM
maineiac13's Avatar
Quoted: 13 Post(s)
I have not noticed any problem like that, I have mine connected via coaxial. Have you tried changing the settings (eg. SRS WOW, etc.)?
You mentioned this was a problem with tv shows. What about DVD/BD? Have you checked out the tv speakers to see if the same thing happens when using those instead of the Vizio?
maineiac13 is offline
post #4 of 8 Old 02-16-2012, 03:27 PM
agent2099's Avatar
Doesn't happen with my 215. I have it connected via optical.
agent2099 is offline
post #5 of 8 Old 01-06-2014, 12:07 PM
bravo6's Avatar
I have the VIZIO S4251 and it does the same thing. Strange thing is, if I rewind my DVR it will fade in the exact same spots every time. If I turn off the Vizio speakers and use the TV speakers, there's no fading in and out.
Connected to a Visio TV via optical.
bravo6 is offline
post #6 of 8 Old 01-07-2014, 10:40 AM
yan101's Avatar
do you have any sort of smart volume or drc enabled? this will change the sound to a more equal level for viewing at night time. It play hell with my set up so i have them switched off
yan101 is offline
post #7 of 8 Old 01-07-2014, 11:59 AM
drfreeman60's Avatar
Liked: 52
Vizio uses the Dolby algorithms for its smart volume control. Unless the TV show that you are watching is broadcast in Dolby, the bar should ignore the signal and deliver normally. However, with an older Vizio soundbar, I noticed that the signal from many TV shows that were broadcast without Dolby volume leveling had something in their signal that made the Vizio want to mute the volume at unintended times.
I turned off both the psuedo surround effects and volume leveling and all worked well for the next fourteen months until the Vizio was demoted to temporary master bedroom duty.
David Freeman
drfreeman60 is offline
post #8 of 8 Old 01-07-2014, 04:35 PM
bravo6's Avatar
I found the 'truvolume' but I believe it was off. I also found a firmware update that supposedly addresses something else mine does (changing channels cause sound to go out and slowly fade back in) but I couldn't get it to install. I need to check the volume leveling..
bravo6 is offline
Reply Soundbars
Vizio Vht215
