Samsung HW-E450 Soundbar - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #721 of 737 Old 12-05-2013, 09:52 AM
RunOfTheDill's Avatar
Originally Posted by atomic50 View Post
I just got a Sammy UN55F6300 over Black Friday and it pairs perfectly with the refurbished HW-E450C I bought last year. I'm partly surprised from what I have read on this thread and trouble I had with my former TV, but just about everything works as expected. The sound bar and TV are connected via HDMI ARC and I am able to control with the stock TV remote; simultaneous power on/off, volume up/down, mute. Similarly, the sound bar remote can control supported buttons also. The only gripe I have is that the volume number doesn't appear on the TV, does on the soundbar, when changing the volume and only an animation. However, the volume number does show up when the mute button is toggled. If anyone has any questions let me know!
so what settings you running with?
RunOfTheDill is offline
post #722 of 737 Old 12-05-2013, 02:32 PM
atomic50's Avatar
Here is everything in clearer list form :)
HDTV Samsung UN55F6300
  • Stock remote Turns on/off TV and soundbar simultaneously
  • Remote adjust volume up/down/mute (only displays corresponding volume level/# when muted, has an ugly animation for volume control)
  • HDMI ARC (Port 2 in this case)
  • Sound output set to Receiver (I think this changed automatically)
  • Anynet+ On
Soundbar HW-E450C
  • Stock remote functions fully with corresponding buttons (TV source, channel, etc)
  • HDMI out, nothing on HDMI in
  • Display says HDMI ARC (I think this setting sticks unless I change manually to another input).
  • Anynet+ On (automatically disables Auto Power altogether)
I was first afraid that I would have to get a F450 to get this to work or even upgrade to a F550, but I will probably save some cash until there is a killer feature in a newer model.
Question for you all: I disabled all of the other enhancement for the soundbar unless someone has a suggestion for one that is worthwhile.
atomic50 is offline
post #723 of 737 Old 12-06-2013, 08:48 AM
  • Anynet+ On
Soundbar HW-E450C
So right now i'm running 3d sound in Cinema/Movie, can't remember the name, also in cinema/movie mode for sound effect with +5 for the sub.  All the other stuff really isn't worth playing with it seems.
post #724 of 737 Old 12-06-2013, 10:12 AM
brazosdog02's Avatar
I have a UN50F6300 TV and a Sony Soundbar, I know its not the soundbar here, but I have a technical question that will be close enough.
If I hook up my DVR to my TV via HDMI
I hook up the TV to the sound bar via HDMI (ARC) (both devices support it)
I turn on my sound bar and watch a dish channel that is sending 5.1.
Do I get 5.1 sound? Is it supported in this setup? Is it 5.1 or compressed to 2.1?
So far NO ONE has been able to answer this question.
brazosdog02 is offline
post #725 of 737 Old 01-05-2014, 11:00 AM
Dabozuk's Avatar
Just wanted to add my experience with setting up this bar to work with my setup. I was tearing my hair out trying to follow the flawed samsung manual (both paper ones in the box and the online support).
But post 672 in this thread simplified it for me, so I'm pretty much repeating his post, but I think it underlines the point that this works, and the samsung instructions are misleading and just plain wrong!
My kit:
  • Samsung 6 series UE46 D6530 WKXXU (ARC capable - googled ARC as I had no idea)
  • Samsung HW-F450
  • Virgin Media TiVo HD
  • PS3 Slim
  • 3 x HDMI cables
Setup steps:
  1. Throw away the manual
  2. Connect HDMI from the HW-F450 sound bar's HDMI Out to the TV's HDMI ARC in (port 2 on my TV)
    This is actually going to be the TV's dedicated audio out, as wells as control of the sound bar (auto off and volume)
  3. Connect TiVo to TV via HDMI (port 1 on my TV)
  4. Connect PS3 to TV via HDMI (port 3 on my TV)
  5. Turn everything on.
  6. Enable Anynet+ on my TV, and in the sub options for Anynet+ I set "Auto Turn Off" to Yes, and set "Receiver" to Off (not sure what enabling this would do with my TiVo - anyone?)
  7. I think step 6 changed my TV's audio output setting to External Speakers, but I may have set that manually, regardless, ensure it isn't using TV speakers.
  8. Enable Anynet+ on the sound bar.
  9. Set sound bar's input to D-In, although this has been renamed to TV ARC... I guess that makes sense.
  10. Set my TiVo remote to work with Samsung code (can't remember which, but I did that ages ago).
So with that setup, the way it works now is that with everything turned off, if I turn on my TiVo and my TV (using TiVo remote) and the sound bar stays off, but audio comes out of the TV.  Then I turn on the sound bar (either with HW-F450's remote, or on the unit itself) and the sound bar takes over the audio, and the TV mutes.
If I switch HDMI inputs to my PS3 (again using the TiVo remote, handy trick) then audio comes out of the sound bar.
Finally, I turn off the TV, and the sound bar turns off too.
For me, this is the perfect setup, as when the kids turn the TV on in the morning, I don't want the sound bar on!!!  But when we want to watch something with a bit more oomph, we just power on the F450 and it takes over the audio.  And for me this sound bar is spot on for my house.  Loud, crisp, bassy and immersive.  Handles dialog, explosions and music equally well.
Spot on Samsung, however you need to re-write your manuals!
Bladerunner1959 likes this.
Dabozuk is offline
post #726 of 737 Old 01-05-2014, 03:57 PM
Doctego's Avatar
Liked: 42
That source selection is also used for an optical connection.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #727 of 737 Old 02-09-2014, 01:52 PM
Mrwacky's Avatar
My kit:
  • Samsung HW-F450
  • PS3 Slim
  • 3 x HDMI cables
Setup steps:
Yes they do need to rewrite and say it right in the manuals and firmware update too it said it got a support of the touch update no clue if this fix for the HW-E450C.  As I have 46"F7100 model and a 40"F6400 models TV as I was reading on this forums I have to say thanks to all of you guys for writing this.
I have bought two of these sound bar I should have waited for a tube rays sound bar for 499.99 but that is little to high$. Or gone for something else. I had to buy two of the HW-E450C for 127.99 after it great price till I didn't dig little bit of reading till now.
I wasted two Optical cable. They didn't comes with cables made me little mad. I thought maybe I could turn up and down from the TV with the speaker turned off on the TV setting and able to move the volume up and down from the optical speaker out and when the TV is off and it will go off because of the no signal in 20 min and when I turn the TV back on then the sound bar will kick on because of the optical is turned on and it has it signal. But I guess not. I wish it was simple like make your remote able to connect another Samsung devices like a remote universal remote learning or added on to the remote itself not the TV itself then to the remote. I guess they need a software engineers to understand what needed to add. To bad no Bluetooth to the TV to the sound bar
As I was looking on the TV I have. It sure does got Sound Share and website from Samsung and I saw Sound Share and I should gone after a sound bar that you have and that supported this it just wireless sound devices able to hook up the TV without any cable and does all the functions. Like the F450 but the F450 got a firmware update :( Lucky you Dabozuk
Mrwacky is offline
post #728 of 737 Old 03-03-2014, 08:26 PM
bobpar's Avatar
Hello- I have recently purchased the Samsung 450 and have hooked up the optical cable. I receive good sound to sound bar however very low volume or performance from woofer.  I am aware of the sound level controller and have it set at +6. Any suggestions. Thanks Bob
bobpar is offline
post #729 of 737 Old 03-06-2014, 06:27 PM
hail2030's Avatar
It depends where you placed it in the room, but as for the settings make sure you have smart volume off and DRC on minimum. That should help increase the performance of the subwoofer.
hail2030 is offline
post #730 of 737 Old 05-06-2014, 11:29 AM
c0nquistad0rian's Avatar
I have read through this entire thread and I need help with my issue.  Basically, my TV stopped recognizing that an Anynet+ device is connected when the soundbar is connected with an HMDI cable via ARC.  The soundbar LCD indicator says TV ARC, indicating that it is connected to the TV and audio is coming from the soundbar but I cannot control the soundbar's volume with the TV remote.
Background:
I have a Samsung UN60ES6100 TV and the Samsung HW-E450 Soundbar.
I have had the TV for over a year and got the soundbar about a month ago.
I have everything set up like so:
TV:
HDMI 1: comcast DVR
HDMI 2 (ARC): Soundbar
HDMI 3: Netgear Push2TV
Soundbar:
HDMI Out (ARC): to TV
HDMI In: Bluray player
When watching cable TV (HDMI 1) or wirelessly connecting my laptop via the Push2TV (HDMI 3), audio projects through the soundbar via ARC.  When watching a Bluray movie (HDMI 2), I change the input on the Soundbar from D. In (ARC) to HDMI and audio projects through the soundbar.
This set up worked fine out of the box and for the first month of having the soundbar.  The only hiccup that existed was that the soundbar would not turn on when turning on the TV but that is a known issue when pairing these two specific devices.  I would just turn the soundbar on with the soundbar remote.  Sometimes it would say D. In rather than switching directly to TV ARC in which case, I would have to press the Anynet+ button on the soundbar remote twice (first to turn off Anynet+ and then again to turn it on).
Last night when trying to adjust the volume with the TV remote, a message popped up on the TV that reads, "Anynet+ device is not connected.  Please check connection and retry."  This despite the fact that soundbar LCD display still reads "TV ARC" and sound is projecting through the soundbar.
I checked the TV's Anynet+ (HDMI-CEC) settings under the System menu.  Anynet+ on the TV is still turned on.  Auto Turn Off says yes.  Receiver is grayed out and says Off.  I pressed the Anynet+ button on the soundbar remote twice (again, first to turn it off and then to turn it back on).  When I did this, Anynet+ menu on the TV says Receiver On.  However, if I highlight and click on Receiver, the setting just changes to Off and I cannot switch it back to the On setting and I get the same message as above.
Taking things one step further, sometimes I can get to an Anynet+ Device List menu on the TV from which I can refresh the Anynet+ connection, which is either unsuccessful (and results in the same message on the TV) or pulls up an option entitled "Player" which will just switch the input to HDMI 2 if I click on it.
Anyone else have this issue of their Samsung TV 'losing' their Anynet+ soundbar?  If so, how do I get it back?
c0nquistad0rian is offline
post #731 of 737 Old 01-19-2015, 04:53 PM
Kruskal's Avatar
Originally Posted by Honeydew11 View Post
Hopefully someone can help.My power bar turns on and off when tv is turned on or off.But power bar doesn't turn on unless I turn the tv on.How do I use the blue tooth feature without having to turn my tv on??
No one answered this as far as I can find. I have the same problem.
TV is connected via optical (D-IN). When the TV is turned OFF, the soundbar is turned OFF -- no 20 minute delay. When the TV is turned ON, the powerbar is turned ON if Auto Power is ON, and not otherwise. This is the only circumstance where the soundbar Power button has any effect.
So I can use Bluetooth only when the TV is ON.
What am I overlooking?
Kruskal is offline
post #732 of 737 Old 01-20-2015, 01:27 PM
Doctego's Avatar
Liked: 42
I didn't follow the entire conversation but this makes sense to me. Depending on how you have the soundbar connected to the TV, the auto power on and off will function as the TV is turned on and off. If you still have the soundbar remote, you can use it to turn the soundbar on and change the input to bluetooth. That or just use the power button and source button on the actual soundbar to make the selection.
Doctego is offline
post #733 of 737 Old 01-21-2015, 10:39 AM
Kruskal's Avatar
But the Power button on BOTH the remote and the soundbar, itself, does not do anything. That is my problem. The only time these buttons will turn the soundbar ON is when it is OFF and the TV is ON. So the button has no purpose for me since the one case when it will do something is the case covered by Auto Power.
Thanks -- Vincent
Kruskal is offline
post #734 of 737 Old 01-26-2015, 11:44 PM
KBoltz's Avatar
Wow
Reading through this thread is like reading the script to one of those horrible 70's disaster flicks like Airport or the Poseidon Adventure.
I decided to go with a different soundbar after all the reading on here.
KBoltz is offline
post #735 of 737 Old 05-21-2015, 06:03 AM
Bladerunner1959's Avatar
Location: Pittsburgh, PA...Preferably the Virgin Islands....
Quoted: 13 Post(s)
Liked: 67
After 2 and a half years of being relatively happy with the HW-E450, I relegated that soundbar to the gameroom with my old Sony rear pro LCD.
I bought the Klipsch r10-B: The Klipsch is an absolute and defined step up on detail and clarity in both vocals and surround details. The bass is different in that its tighter and less boomy in a constant way like Sammy was. But it roars when called upon for action or music.
Aestetically I loved the slender 450 but my wife and I were tired of missing some dialogue and detail. I'm happy I have another place for the 450 but no remorse at all about replacing it as my main audio source. The Klipsch matched with my Samsung UN60es8000 is bodacious!!!
Love for all things Hi-def...Losing count; 200 plus bluray, 500 plus dvd, 30 plus HDdvd and a rapidly growing 50 plus in the cloud.
Bladerunner1959 is offline
post #736 of 737 Old 05-24-2015, 03:05 PM
kbennett65's Avatar
finally works
Well I finally got this thing working right. Can't believe how long that took! Equipment is an RCA TV [coax cable for digital sound], the soundbar [toslink cable], Sony BluRay and Motorola cable/DVR box
I connected the TV to the soundbar using a toslink to coax converter and wouldn't you know the first time I tried this I bought the converter with the in and out options the wrong way. I had given up on this until I finally figured out the converters can be set up different. After buying the right one, amazingly it works. Big oops on my part for messing that up the first time.
BluRay and DVR box are just connected directly to the TV via HDMI cables. Turns out I was making these connections much more complicated than it needed to be.
The big kicker was trying to control everything with one remote as using 2 to 3 remotes for everything was a big pain. I never though I'd find a universal remote that would work with my cable box as Charter is notorious for not working well with remotes other than their own. I bit the bullet and bought the Harmony 650 for a good enough price that if it didn't work I wasn't out a ton of money, but shocker...it works great! Now one button turns everything on or off and the soundbar volume is controlled through the Harmony remote without issue.
kbennett65 is offline
post #737 of 737 Old 09-26-2015, 08:50 AM
lament's Avatar
Hi all,
I have a Vizio M60-C3 with HDMI 1 going into HDMI OUT on my Samsung HW-E450 soundbar with a brand new Amazon Basics high speed HDMI cable.
Samsung shows TV ARC as soon as Anynet+ is turned on (turning it off puts the Samsung back to D.IN and the Vizio speakers come on).
Vizio discovers the soundbar as SAT under CEC > Device Discovery and is set to ARC ONLY (also tried Enabled) but I have no sound.
Also tried HDMI IN on the Samsung - same results.
Anyone using an HW-E450 with an M series that has this working?
Thanks for any help.
edit: weirdly, just now with the source playing audio (via optical), I unplugged the optical cable and plugged in the HDMI OUT on the Samsung, and it's working.
Audio is set to PCM and CEC is enabled, but I didn't select Discover Devices.
I just turned off the TV and it subsequently turned on the soundbar (good). Turned on the TV and the soundbar also came on (good) - and TV ARC is showing and we still have audio.
Not sure what happened, but I'm leaving it.
oh hi.
lament is offline
Reply Soundbars
Samsung Hw E450 Wireless Airtrack Soundbar
