Yamaha YSP1000 vs YSP4100/YSP5100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-22-2012, 05:07 PM - Thread Starter
improwise's Avatar
Quoted: 17 Post(s)
I have a Yamaha YSP1000 that is probably 3-4 years old by now, and I am thinking of upgrading it to a YSP4100 or YSP5100. So my simple question is how would you rate the YSP4100 and YSP5100 against the old YSP1000? Or perhaps put in another way, has the technology evolved enough so that you will be able to hear the difference between them assuming the rest of the factors are the same (same room etc)? I'm mainly interested in surround sound here, or at least TV/Movie sound.
improwise is offline
post #2 of 2 Old 04-02-2012, 11:09 PM
badbenzz's Avatar
I use a YSP4100 in my bedroom which replaced a complete 5.1 system including Kef reference 205's and the matching monster center, which was overkill for the bedroom. The YSP4100 sounds good and does well in a bedroom setting. The YSP also passes 3d.
badbenzz is offline
Reply Soundbars
Yamaha Ysp 4100bl Digital Sound Projector Black , Yamaha Ysp 5100bl Digital Sound Projector Black
