Help me PLZ - Panasonic sc htb15 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-27-2012, 01:00 PM - Thread Starter
waxwabbit's Avatar
Hello everyone
I just purchased the Panasonic SCHTB15...........and I need a little bit of help.
I followed the instructions, and still it won't work...........
So can you tell me where I am going wrong?
I have the SUB WOOFER OUT hdmi (arc compatible) cable going into my LG 47LW5700 ARC hdmi 1
My cable box is HDMI going into hdmi 2 on LG tv
I turned off tv speakers........i enabled ARC on tv
Still no sound
I was messing around, and switched it so that my cable box hdmi went into the 2nd hdmi port on the SUB - then i get sound.......However, my Playstation 3 (hdmi going into hdmi 3 on LG TV) then has Picture - but the sound of the Cable box.
I called both Panasonic and LG. Panasonic said my original set-up should have worked.
The LG guy, was basically reading out aloud a TROUBLESHOOTING booklet - and still couldnt figure it out. He said I needed 2 optical cables - 1 for the cable and 1 for the PS3! I said that I may as well do it my way (and could I get 1 optical cable for the PS# straight into my LG TV?!!!
Anyway
Thanks for reading, and apologies for my ineptitude
waxwabbit is offline
post #2 of 5 Old 03-27-2012, 01:45 PM
Possumgirl's Avatar
Liked: 58
Connect both your cable box and PS3 to the two HDMI in ports on the sub. Connect HDMI out from sub to TV's HDMI(ARC) in, as you had it. You should have video passing through to the TV and audio being processed directly by the soundbar. That's supposed to work.
Possumgirl is offline
post #3 of 5 Old 03-30-2012, 11:10 PM - Thread Starter
waxwabbit's Avatar
lol
Thanks for the fix
I cant believe the so called experts for LG AND Panasonic couldn't help me
Actually - yes I can
Cheeeeeeeeeeers
post #4 of 5 Old 04-20-2012, 01:35 PM
mahpoo7782's Avatar
hi i want to ask can it work with normal hdmi input of tv suppose i want to attach settop box hdmi out to sub hdmi input 1 and sub hdmi (arc) output to tv hdmi(normal) input
mahpoo7782 is offline
post #5 of 5 Old 04-20-2012, 02:06 PM
Possumgirl's Avatar
Liked: 58
Of course. You only need ARC (or digital) out if you have something attached to the TV, use the TV's internal tuner or have smart apps on the TV.
Reply Soundbars
