Soundbar sub, where to place? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-13-2012, 08:14 PM - Thread Starter
elykoj's Avatar
I bought the Samsung HW-E450 sound bar and I wanted to know what is best position for the wireless sub? Should I put it next to tv facing us, or put it behind us? What position gets best sound?
elykoj is offline
post #2 of 9 Old 04-13-2012, 08:36 PM
Audiophile34's Avatar
Considering the output levels of the sub is question, I would condsider corner loading to get the benifit of output that comes with that. Otherwise as close to Lp is going as possible is going to give you the most enjoyable experiance.
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
post #3 of 9 Old 04-13-2012, 10:22 PM - Thread Starter
elykoj's Avatar
What is an LP? Corner load it in front or behind? I really don't understand your answer? Sorry
elykoj is offline
post #4 of 9 Old 04-14-2012, 09:22 AM
Possumgirl's Avatar
Liked: 58
LP = listening position. To find the best place for your sub, try the "sub crawl". Place the sub at your main listening position, put on some music with lots of bass, crawl around the room to see where the bass sounds loudest. That's where the sub should go. Google sub crawl for more info. Generally speaking, placing a sub in a corner (any corner) gives you more bass.
Possumgirl is offline
post #5 of 9 Old 04-15-2012, 07:08 AM
NoStatik's Avatar
Audiophile34 is partly correct. Generally corner loading a sub is ideal, bit from my experience with the hw-e450, it will sound boomy. But you can start by placing it in the corner that's closer to.the sound bar, so you get nice mixing. From there, use the sub crawl, to pinpoint the perfect location. Problem I see with corner loading is the booming effect and the fact the a lot of people have their couch against a wall, which makes it considerably overwhelming.
- "K"
Fry's Electronics A/V
NoStatik is offline
post #6 of 9 Old 07-02-2012, 12:32 PM
Peter Daintree's Avatar
Hi there i cant get any sound to come out of the Sub Woofer, can anyone help????
Peter Daintree is offline
post #7 of 9 Old 07-06-2012, 11:10 PM
prme19's Avatar
Quoted: 420 Post(s)
Liked: 385
total noob here.. does it matter which side of the subwoofer faces what? do you want the softer vibrating panel to face the wall/couch? did sub crawl but couldn't tell where the best place for the bass is.. need help please..
my JS8500 movie calibration settings as of 8/8/15 http://www.avsforum.com/forum/166-lc...l#post34495410
my JS8500 standard calibration settings as of 6/18/15 http://www.avsforum.com/forum/166-lc...l#post35124130
prme19 is offline
post #8 of 9 Old 12-31-2013, 02:10 PM
PinkWonderGirl's Avatar
I can't figure this out either. There is the big soft vibrating panel and then there is the narrow front with the speaker. I have no clue which way it is supposed to be facing. I am getting frustrated since I keep googling and can't get anything.
PinkWonderGirl is offline
post #9 of 9 Old 01-02-2014, 03:23 PM
drfreeman60's Avatar
Liked: 52
Place the side that has the label "Samsung" facing forward. Since the woofer covers a fairly large audio range, the best overall sound will be to place the woofer close to the soundbar and in the same plane if possible.
Corner loading can be correct for some true sub-woofers or certain speakers designed for corner loading, otherwise it has the potential to muddy the sound.
Where you have a woofer that goes up fairly high into the mid-bass range, there can be a sonic disconnect to have it too far away from the soundbar.
David Freeman
drfreeman60 is offline
Reply Soundbars
Samsung Hw E450 Wireless Airtrack Soundbar
