Does Dolby Digital and DTS really matter with Sound Bars - AVS Forum | Home Theater Discussions And Reviews
Old 04-18-2012, 07:14 AM - Thread Starter
ScottBeckstead's Avatar
Hello all,
I am looking at 2 and 2.1 active sound bars and have noticed that many of these sound bars support Dolby Digital, DTS and similar multi-channel audio formats. My question is, how relevant is Dolby Digital, DTS, etc when the sound bars are capable of of only supporting 2.1 channels? Do Dolby Digital, DTS, etc benefit me in any way using these sound bars?
Scott
ScottBeckstead is offline
Old 04-18-2012, 08:19 AM
elykoj's Avatar
I am wondering the same?
elykoj is offline
Old 04-18-2012, 01:20 PM
davyo's Avatar
Originally Posted by ScottBeckstead View Post
Hello all,
Scott
Do soundbars that support DD and DTS benefit,,,,,, depends on who you ask and which soundbar it is.
Im not even sure I know to be honest.
Each soundbar process's sound its own way and each soundbar maker has a fancy name for their processing.
I Know in the past I have seen some on here make comments like " Ohh, I would never buy "that" soundbar,, it does not support HD audio",,, my reaction is always, really dude,, its a soundbar,,,, its not going to make a rats ass of difference if "that" soundbar does HD audio or not,,, its a soundbar !!!
Cheers
Davyo
davyo is offline
Old 04-18-2012, 03:44 PM
gregzoll's Avatar
Liked: 33
Most of the time it is cirtual simce it is only two channel. It does help to "open" the sound field, when watching tv and movies. Since majority of the time, it sounds like tv shows and movies, when listening through a 2 channel system sounds "tighter" or compressed.
gregzoll is offline
Old 04-19-2012, 08:57 AM
TulsaCoker's Avatar
I have hooked up my Zvox580 both from the TV (Panny optical) which is 2.0 and directly from the Cable box and blu ray player. Maybe a slight difference but it also could just be in my head.
sheshechic likes this.
TulsaCoker is offline
Old 04-29-2012, 07:54 PM
500GB's Avatar
As far as I know, when you make a digital audio connection between two devices, it's important that the receiving device is able to "handle" the digital format sent by the source device.
For example, if your set-top box is sending PCM 2.0 (i.e., digital stereo). ANY soundbar with a digital input should be compatible with that signal. If however, the box is set to output Dolby Digital (5.1 multichannel) and your soundbar doesn't do that format, then you'll either get just the L/R signals without any center channel mixed in, or no output at all. Soundbars that can decode Dolby Digital and/or DTS signals are therefore a neccessity when the source device cannot be set to send PCM 2.0. Most such soundbars simply downmix the 5.1 channels down to stereo, but that's at least the right way to handle the signal, IMHO.
500GB is offline
Zvox 580 Low Profile Single Cabinet Surround Sound System With Optical And Coaxial Digital Inputs
