Sony CT150 Y cable for iphone - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-18-2012, 12:28 PM - Thread Starter
sarb0013's Avatar
I'm trying to use my iphone through my sony CT150 without needing to buy the dmport dock. Is there a way I can just connect the ipod using a y cable?
sarb0013 is offline
post #2 of 5 Old 04-18-2012, 12:49 PM
Possumgirl's Avatar
Liked: 58
Yes
Possumgirl is offline
post #3 of 5 Old 04-18-2012, 12:57 PM - Thread Starter
sarb0013's Avatar
What inputs do I plug the cable into? I tried the audio in labeled SA-CD/CD and set the sub to that input but did not get any sound.
sarb0013 is offline
post #4 of 5 Old 04-18-2012, 01:37 PM
Possumgirl's Avatar
Liked: 58
Hmmm. Should work. Mine did. Make sure you have volume turned up on the player. My MP3 player isn't an iPod, but connection should be exactly the same.
post #5 of 5 Old 04-18-2012, 03:10 PM - Thread Starter
sarb0013's Avatar
Figured it out, stupid mistake. Thanks though!
sarb0013 is offline
Reply Soundbars
Sony Ht Ct150 Virtual 5 1 Channel Sound Bar And Subwoofer Set Accessory Kit
