Panasonic SCHTB550 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 42 Old 11-23-2012, 12:37 PM
buckeye13's Avatar
I'm hoping someone can help me with what seems to be an issue with my HTB550.
My PS3 is connected via HDMI directly to the soundbar. The soundbar is connected via HDMI (ARC) to the TV (ARC enabled). The issue is even if I play a bluray movie or any content that
comes with Dolby Digital or DTS sound, the sound bar is indicating only PCM (only PCM indicator lights up) is active. I can't get the sound bar to have the Dolby Digital (DD) or DTS indicators to light up. I already checked the audio settings for my PS3 (DD and DTS are enabled). I also made sure that the bluray movie is set to DD or DTS in the setup menu. I thought that DD or DTS or any virtual surround can be activated if the PS3 is directly connected to the sound bar. Anything else I can do to solve this issue?
buckeye13 is offline
post #32 of 42 Old 11-26-2012, 01:03 PM
InstantCole's Avatar
What I'm guessing is happening is that the PS3 is recognizing that you do not have a 5.1 sound system hooked up and is sending the PCM signal. This is probably best too because if it sent the DTS there wouldn't be any surround speakers to play audio.
It's just a guess
one321 likes this.
InstantCole is offline
post #33 of 42 Old 11-29-2012, 10:24 AM
GatorRican's Avatar
Quoted: 37 Post(s)
Liked: 26
Can someone please confirm whether or not a volume NUMBER shows on the screen of a VIERA Link connected Panny TV when using the HTB550? I plan on purchasing this sound system but can't seem to get a definite answer. I know a volume bar shows up on the TV screen when using the TV remote to lower/raise the sound coming from the HTB550, but what I am asking is; Will a volume number show up?
That is to say: Can I tell my son "keep it at 21" and he would be able to see the"21" volume level on the TV screen...!? rolleyes.gifrolleyes.gif
TV: Panasonic TC-P55ST50
BluRay: Panasonic DMP-BDT 220
Audio: Sony HT-CT100 (Currently testing Vizio SB4051)
Gaming: PS4
PSN: Rican21
GatorRican is offline
post #34 of 42 Old 12-02-2012, 03:50 PM
hlam36's Avatar
Hi everyone. I'm new to this forum and to all this high tech stuff. I recently bought a Panasonic gt50 and was looking for a good sound bar for the living room. The tv will be mounted above the fireplace and it makes it difficult to run wires. My question is if I have the sound bar sitting on the mantel and hooked up via hdmi arc and viera connect, can i hide the sound bar's main processor? The mantel isn't very deep so the processor doesn't fit neatly on it. I'm not too concerned with switching inputs since they're connected to the television.
How does the volume work via Viera connect? Do I point the remote to the TV or will i still have to have point the remote at the HTB550's main processor?
thank you very much.
hlam36 is offline
post #35 of 42 Old 12-02-2012, 04:14 PM
Possumgirl's Avatar
Liked: 58
The TV is the "control", so once Viera Link is enabled you just aim the remote at the TV to adjust volume. You can also have the soundbar turn on/off with the TV if you choose to do so. To make any adjustments to the soundbar however, you'll need to use its remote and have access to the processor unit. Typically that's not something you'll do after initial setup and tinkering. smile.gif
Possumgirl is offline
post #36 of 42 Old 12-02-2012, 04:26 PM
hlam36's Avatar
Thank you very much for the info Possumgirl. That solves my problem. The sound bar will be perfect for my needs.
hlam36 is offline
post #37 of 42 Old 12-03-2012, 09:22 AM
GatorRican's Avatar
Quoted: 37 Post(s)
Liked: 26
Do you know the answer to my question?
Gaming: PS4
PSN: Rican21
post #38 of 42 Old 12-03-2012, 09:35 AM
Possumgirl's Avatar
Liked: 58
Sorry, I don't know. I've never used the Panny bar. When I had a Sony bar connected to my Panny TV, volume level # did not display onscreen. Now I'm using a Denon AVR and it does display volume level onscreen. In both cases, my source devices are connected to the external system, not the TV. I do know when you set a Panny TV to external audio, the TV just displays that home theater bar with no numbers.
post #39 of 42 Old 12-03-2012, 10:24 AM
GatorRican's Avatar
Quoted: 37 Post(s)
Liked: 26
Gaming: PS4
PSN: Rican21
post #40 of 42 Old 12-30-2012, 12:59 PM
tmmuch's Avatar
YES
NUMBERS!
At least they show up on my Viera screen OK.
I've turned off the TV speakers and turned on "Home Theater" speakers in the Viera settings.
The on-screen volume indicator now shows: "Home Theater volume
45"
tmmuch is offline
post #41 of 42 Old 12-30-2012, 01:21 PM
gomo657's Avatar
Quoted: 136 Post(s)
Liked: 119
If the ps3 is set to bitstream you'll get the notifications but it will be lossy it you set it to PCM you'll get Dolby true hd/dts hd to the soundbar.
"well you know what doctor I'm going to go home take two aspirins and call you a b****"
gomo657 is online now
post #42 of 42 Old 01-07-2013, 01:29 PM
one321's Avatar
My Panasonic TC-P55GT50 is connected to a SCHTB550 sound bar. The sound bar turns on when the TV is turned on. I control the sound through the TV remote just fine without issues. However, if I have the TV's Netflix app paused or sitting in the home screen for a while my TV will turn on the screen saver and eventually shut off the sound bar. At the same time, it switches the TV's audio setting from Home Theater back to TV even though I have the TV speakers disabled. If I am in regular TV, I can just the Viera Tools to access Viera Link and switch back to Home Theater, which turns the sound bar back on. However, when I am in Netflix or any Smart TV app, I have to exit that app in order to access Viera Tools and the Viera Link option. I hope I'm not losing you here. Alternatively, I can use the sound bar remote to turn the sound bar back on, which isn't convenient for where I have the sound bar placed. Does anyone know how to get the TV to stop switching back from Home Theater to TV for audio and at the same time stop it from shutting off the sound bar, which only occurs if the TV is left sitting without media playing?
Edit: I looked through the manual many times but always overlooked this little nugget. Since there aren't a whole lot of settings and options with this thing, I'm guessing there isn't a way to extend or disable standby.
one321 is offline
Reply Soundbars
Panasonic Sc Htb550 2 1 Channel 240 Watt Multi Positional Full Hd 3d Audio System With Wireless Musi
