vizio vsb200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 05-01-2012, 12:55 PM - Thread Starter
Jordan1126's Avatar
i picked up one of these units for a good price and purchased a polk audio 10 inch subwoofer. i have no idea what i should set my crossover at? im not sure if the vizio soundbar regulates it and I should just set it to max, or if i have to set it to a specific setting, eg 110hz?
thanks for your help
Jordan1126 is offline
post #2 of 35 Old 05-01-2012, 06:19 PM
Leo King's Avatar
Try varying the crossover control b/w 150-180Hz until you find the point that gives the best overall sound.
Leo King is offline
post #3 of 35 Old 05-01-2012, 06:25 PM - Thread Starter
Jordan1126's Avatar
Ok thanks. How come so high though
post #4 of 35 Old 05-01-2012, 08:58 PM
Leo King's Avatar
Because the four 3" midbass drivers on the soundbar can't go lower than around 150Hz.
Leo King is offline
post #5 of 35 Old 05-01-2012, 09:20 PM - Thread Starter
Jordan1126's Avatar
Thank you for the advice. I appreciate it
Where did u find those specs If you don't mind me asking
post #6 of 35 Old 05-01-2012, 09:23 PM - Thread Starter
Jordan1126's Avatar
FLAT PANEL SOUND BAR
Speaker bar frequency response: 60Hz to 20kHz
Integrated Class-D Amplifier at 20x2 channel with 0.01% THD
S/PDIF receiver for digital audio delivery
102db Dynamic range
Support for PCM input via TOSLINK input
High Power Efficiency with Low Power Consumption
Found this on the website. Would it not indicate it goes as low as 60
post #7 of 35 Old 05-01-2012, 09:45 PM
Leo King's Avatar
User's Manual for the VSB200
The manual lists the sizes and the number of drivers.
The manual does not list the true freq response of the sound bar but I used my test CDs to measure it and it showed ~ 150-18,000Hz +/-3dB.
Leo King is offline
post #8 of 35 Old 05-01-2012, 09:50 PM
Leo King's Avatar
102db Dynamic range
Nope, if we consider the +/- 3dB @ 1W/1m it definitely can't go down to 60Hz. It could only go down to around 150Hz coupled with the room response, that's the reason I suggested you varied the X-over freq control from 150-180Hz to see which point would give the best sound in your room.
Leo King is offline
post #9 of 35 Old 05-01-2012, 09:52 PM - Thread Starter
Jordan1126's Avatar
Ok awesome. Thanks. I me to this. So I should set my crossover at 150? It goes to 160 max. It is the polk pws10 sub. also how do I go about setting the volume for the subwoofer (any tips?).
post #10 of 35 Old 05-01-2012, 09:59 PM
Leo King's Avatar
Yep, please set the Crossover Freq control to 150Hz 1st then change it to 160Hz to see which one you like better. Just set the bass volume control to the point that the bass does not overpower the rest of the audio. This depends on the volume of your room, the furniture in the room, how loud you like to listen to the bass so it's hard to tell what would be the right level setting. You will need to do some experiments with the settings to find the right ones for you and your room.
Leo King is offline
post #11 of 35 Old 05-01-2012, 10:26 PM - Thread Starter
Jordan1126's Avatar
Great! I will try that out and start the volume at the midpoint and tweak from there. Hopefully the sub can handle the frequency. I guess can't complain for 250 all in. I'll prob just leave at 150 cause I doubt I will tell the difference and I am more or less guessing on the exact positioning of the knob.
Any advice on phase setting. Right now I have it at 0
post #12 of 35 Old 05-01-2012, 11:35 PM
Leo King's Avatar
The phase setting is very simple. Depending on the location of the sub in the room, sometimes we need to set the phase to reverse to get better bass response. You need to play some music or a movie that has lots of bass then alternately switch the phase control b/w the Normal and Reverse positions. The setting that gives better bass is the right one.
Leo King is offline
post #13 of 35 Old 05-02-2012, 10:31 AM - Thread Starter
Jordan1126's Avatar
Ok great. So I set it all up and it sounds really good. For the price I paid I am extremely happy. I'm assuming if this had a built in crossover setting we wouldn't have to worry about the back of the sub regarding the crossover
post #14 of 35 Old 05-02-2012, 11:08 AM
Leo King's Avatar
I am happy for you, too. I agree with you the soundbar with the added subwoofer does sound really good, especially for the money we paid for it. I had 2 VSB200's, one for me and the 2nd one for my GF. I am running an AR 150W 8" subwoofer that I bought several years ago before Audiovox took over AR with my VSB200. For my GF, I bought her a 100W 10" Sony sub. Both sound very good and we're very happy with our SB's.
Leo King is offline
post #15 of 35 Old 05-02-2012, 11:30 AM - Thread Starter
Jordan1126's Avatar
thats awesome, thanks again for the advice. I was reading other forums and was getting mixed opinions. some assuming that the soundar sent the crossover at 110hz etc. im glad you did the actual tests and know what is going on.
do you ever use the trs surround feature?
post #16 of 35 Old 05-02-2012, 12:22 PM - Thread Starter
Jordan1126's Avatar
also, one more quick question. my blu ray player has a few options for audio. one is to send it as pcm stereo, one is to send it as DD, and the other is to pass through. right now i have it set at passthrough, would this be the best option?
post #17 of 35 Old 05-02-2012, 12:22 PM
Leo King's Avatar
I can confirm that the VSB200 does not send the audio signal that's crossed over @ 110Hz to the Sub Out jack. I tried the surround effect but did not like it.
If you use the optical connection, set it to pass through or PCM.
Leo King is offline
post #18 of 35 Old 05-02-2012, 02:51 PM - Thread Starter
Jordan1126's Avatar
so i played around with the volume while watching inception. i found that it sounded pretty good at about the 2:00 o clock position, so between half and three quarters. Where is yours if you dont mind me asking.
I did find that watching cable there really isnt much bass going on, even on movies, but maybe because the feed isnt as good, and i wouldnt want to increase the level and have to change it when i watch movies
post #19 of 35 Old 05-02-2012, 03:01 PM
Leo King's Avatar
You're right, DVD/BD movies would give lower and tighter bass than regular TV programs. Mine was set at 1:00 so it's about what you set yours @.
Edit: If you have HD cable channels, they should give the bass that rivals the bass from DVD/BD movies.
Leo King is offline
post #20 of 35 Old 05-02-2012, 06:12 PM - Thread Starter
Jordan1126's Avatar
I guess I always expect it to be booming when in all reality it is often just subtle. Like real life
post #21 of 35 Old 05-02-2012, 06:23 PM
Leo King's Avatar
The HD channels on my DTV have plenty & very good lows. The SD channels also have good lows but less solid and not as low.
Leo King is offline
post #22 of 35 Old 05-02-2012, 06:34 PM
Leo King's Avatar
How did you connect the cable box to the soundbar? Maybe there is something wrong with the connection.
Leo King is offline
post #23 of 35 Old 05-02-2012, 07:25 PM - Thread Starter
Jordan1126's Avatar
Everything is hdmi to my 3dtv. Then optical out
post #24 of 35 Old 05-02-2012, 07:37 PM
Leo King's Avatar
If you set the TV's optical out to Pass-Through, try changing it to PCM to see if it will improve the bass output.
Also,
- Placing the subwoofer close to a wall will emphasize the bass. Placing the sub in one of the corners in the room will even make the bass stronger.
- The Polk subwoofer has 2 line-in jacks but the VSB200 has only 1 subwoofer line-out jack. I suggest you use a Y adapter like this one to connect them to get fuller bass from the sub.
Leo King is offline
post #25 of 35 Old 05-02-2012, 08:11 PM - Thread Starter
Jordan1126's Avatar
I bought a split subwoofer cable already.
Te tv optical out doesn't have any setting. I turned the tv speakers off and I believe it passes it through the same way it is received
post #26 of 35 Old 05-02-2012, 11:04 PM
Leo King's Avatar
I suggest you also connect the cable box to the sound bar via 1 of the 2 RCA input connections on the SB then select that input to see if the sound from the cable box gets any better.
Leo King is offline
post #27 of 35 Old 05-03-2012, 06:56 AM - Thread Starter
Jordan1126's Avatar
I tried connecting the cable box directly to the soundbar through optical and it was the same. It's not that it sounds poor. I was just comparing it to An action scene from the dark knight and obviously it isn going to be that much bass on a show like csi
post #28 of 35 Old 05-03-2012, 09:18 AM
Leo King's Avatar
Maybe you had too high expectation.
Leo King is offline
post #29 of 35 Old 05-03-2012, 10:30 AM - Thread Starter
Jordan1126's Avatar
that may be the case lol
i found this, does it mean anything? lol
http://www.hometheater.com/content/v...-labs-measures
post #30 of 35 Old 05-03-2012, 11:23 AM
Leo King's Avatar
The graph on that page showed @ 90dB SPL @1 meter, the -3dB point of the lower frequency end was around 150Hz (the author said it's 155Hz) and the useful upper end (~ -3dB) was about 18KHz so the graph also agrees with what I found when measuring my VSB200 (coupled with the room response in my room). At 85dB, the frequency response of the sound bar gets much better but 85dB is a very low level to consider given the weak built-in amps on the SB.
But that's for the VSB210WS, not the VSB200. I believe the 2 are pretty close in sonic performance.
Edit: I just checked the Vizio website. The 200 and the 210WS are actually the same SB with the added wireless sub for the 210WS.
Leo King is offline
Reply Soundbars
Vizio Vsb200 Universal Hd Sound Bar
