Soundbar with clear dialog - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-04-2012, 07:50 AM - Thread Starter
bobbee25's Avatar
I have a 50" Samsung and would like to get more dynamic sound. I tried a Vizio and also a JVC BA1. The problem is that when there is quite a few different sounds, they sound muddy and it is hard to understand the dialog. So I shut them off and revert back to the TV speakers.
Is there a sound bar that doesn't overwhelm the dialog and has a clear range (not muddy sounding). I would like to stay under $300. I was reading about 2 possible units on the internet, but of course you need to buy them to find out if they will do the job.
Yamaha YAS-101 and Sony CT150
(I have a subwoofer)
bobbee25 is offline
post #2 of 6 Old 05-04-2012, 05:40 PM
valley_nomad's Avatar
The soundbar that has a dedicated center channel/speaker usually can deliver better dialog. Of course the connection between your audio source and the soundbar should be able to pass the channel first.
valley_nomad is offline
post #3 of 6 Old 05-05-2012, 05:51 AM - Thread Starter
bobbee25's Avatar
any recommendations ?
The Sony HT-CT150 appears to have a center speaker.
bobbee25 is offline
post #4 of 6 Old 05-05-2012, 10:07 PM
Yes, Sony's 3.1 soundbar should be able to give you better quality on dialog channel.
post #5 of 6 Old 05-27-2012, 02:00 PM
ccll0's Avatar
i was searching for something similar. came across this http://www.hometheater.com/content/z...oundbar-page-2
down towards the bottom it mentions how well the dialog was.
ccll0 is offline
post #6 of 6 Old 06-02-2012, 07:12 AM
G.M.'s Avatar
[b]The ZVOX does have a "Dialogue Emphasis" that can be activated via a button on the remote. It is effective but when used, it does cancel out any surround sound features that you may have previously selected.
-George
G.M. is offline
Reply Soundbars
